Battery charger that's solid and dependable?
Old Nov 6, 2021 | 07:03 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I have two CTEK’s. They’re great
Old Nov 6, 2021 | 08:48 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Newer GM cars and all car makers(?) have desulfication function in the cars charging system. Pretty neat.
Old Nov 6, 2021 | 01:58 PM
C3 Stroker's Avatar
C3 Stroker
Great results with this one for the past 7 years, all battery types and a 125A starter...
Amazon Amazon
Old Nov 8, 2021 | 02:59 PM
68/70Vette's Avatar
68/70Vette
They are standard/optional with an impressive range of upper end auto brands.
Old Nov 8, 2021 | 04:52 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I use a BatteryMinder. I have the 2012 and a 2012 AGM for the optima batteries. I have been running this charger for years, and my 2001 Z06 has an Optima from 2006 still going strong. https://www.batteryminders.com/2012-...-worldwide-use
Old Nov 8, 2021 | 07:22 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Originally Posted by Engage
My CTEK failed after 2 seasons of use.... also if power goes out you have to reset them.Trying a Noco now with a desulfater...does not need resetting when power goes out....will see how long it lasts
I just picked up this Noco Genius G4 at Canadian Tire on a clearance sale for $179 Cdn regular $279. Its a discontinued model but the technology is new enough for me. My old Battery Tender has served me well for the last 15 years but this Noco will charge/maintain 4 batteries.
Old Nov 14, 2021 | 10:35 AM
SharkAttack's Avatar
SharkAttack
I've used the Deltran Battery Tender Plus for many years, no issues and they have worked well for me. Have one on the Corvette and the "Jr" model on the motorcycles, lawn tractor and generator.
Old Nov 15, 2021 | 08:12 AM
augiedoggy's Avatar
augiedoggy
Originally Posted by Bikespace
I just use a $10- battery disconnect. I've let the car sit for 6 months, reconnect battery, two pumps of the gas, a long crank and it starts up.
I have a few choices of charger if I need, and usually pull the battery and charge on the bench, but I would never leave a car unattended on any type of charger. It isn't worth cleaning up an acid spill, even once.
been there... still have a corroded mess on my concrete garage floor from this.
I recently used a "smart" charger to recover (Desulfate) an old battery and I am a believer. I also used it to desulphate my campers solar battery bank. I still dont leave them connected long term but over the winter ill connect my chargers for a day or 2 on the slow charge setting to basically keep a charge in it.
I dont do anything to my riding mowers battery and the last one lasted 7 years so go figure...
Old May 9, 2024 | 06:48 PM
rpoL98's Avatar
rpoL98
i have a daily driver (no battery tender), and about 6 dormant vehicles, all with battery disconnect switches and 24/7 battery tenders, maybe get driven once a year. I'm beginning to lose faith in my battery tenders, and unfortunately I'm heavily vested in them. after a few years of 24/7 use, solid green indicator, one day, the battery tender goes to blinking yellow, and no matter how much you futz with the connection, it stays blinking yellow.
I recently acquired a NOCO Genius10, put that on there, wait till the indication got up to solid green, and then put it into "repair" mode. Then put the NOCO back to maintain mode for a few days or a week. Then I put the Battery Tender back on, and it goes to solid green. And these are new, recently bought Battery Tenders, not clearance or anything like that. I now have 3 of the Genius10, and they cost twice as much as the Battery Tenders.
The proof is in the pudding. I go to start my 454 Dually, only get the sickening click-click-click. This is with the Battery Tender 24/7, solid green. Put a jump starter pack on there and it fires right up. I put the NOCO on there for a few days, hit the repair, and that one took a day or so, overnight, to finish the repair mode. put it back to maintain mode, and a few days later see if it will start, vroom, started right up.
454 C3: went out to start it up, dead battery, even though 24/7 battery tender. Went and bought a new battery, started right up, no surprise. I didn't turn in the dead battery as a core, kept it. Hooked up the NOCO to it, as per instructions, let it get to fully charged before doing the repair mode, took a while doing the repair, was wondering if it would ever come out of repair mode, finally it did, and now it's solid green. Hopefully I can get a few more years out of that battery. I currently have another C3 without a battery ...
I'm also going to try out the NOCO Genius5 and the Genius2, figure I don't need the repair function on all my chargers, can just move them around as needed. And I also ordered a BatteryMINDer 2012 and BatteryMINDER 1500 to see how those perform.
I also have a couple of Pulse Tech Xtreme Charge XC100 chargers (red/black), but those are also long since retired due to flakiness.
just my observations, FWIW. YMMV.
Old May 11, 2024 | 09:28 AM
augiedoggy's Avatar
augiedoggy
Originally Posted by brassplyer
Subject line pretty much says it. What's a battery charger that will work when you fire it up after it's been sitting for 6 months or a year later?
This is more informational for anyone reading this but from what I understand you wont find any newer "chargers" that do this... You need a battery "tender" or "maintainer" or sometimes referred to as a trickle charger instead. And there is a difference in MOST cases and many are one or the other.
From what ive read its now an energy star requirement that chargers shut off once the battery is fully charged and that they dont continue to kick on and off. Tis is a HUGE issue on the golf cart forums because people think thier chargers will automatically kick on and off and maintain a constant state of charge.
You can setup the charger on a timer system to reengage it periodically but the better option is to buy a maintainer.
In case anyones wondering the government provides incentives to make the chargers this way since it does cut down on wasted energy (and likely contributes to thousands of wasted batteries every year in the process)
BTW the Noco chargers are great, they are the only ones to make a proper charging system for multiple lithium batteries wired in a series while keeping them balanced as well.
Old May 11, 2024 | 06:44 PM
JCurtiss's Avatar
JCurtiss
Originally Posted by 68/70Vette
I have three CTEKs in use. I like them, they have logic to control their trickle and charge modes. CTEK is the charger you get if you order a C8 Corvette with the battery protector option. They are also standard equipment for some models of Porsche and Ferrari.
Yep, CTEK here too!
Jason
Old May 11, 2024 | 07:07 PM
brassplyer's Avatar
brassplyer
Thanks - what I was getting at is known brands/models of chargers that people have found will actually work when they've been sitting unused for long periods not just when they're new.
Since first posting this in 2021 so far the Schumacher I got at O'Reilly is hanging in there.
https://www.oreillyauto.com/detail/c...+charger&pos=6
Old May 11, 2024 | 08:34 PM
  #33
Alwyn678's Avatar
Alwyn678
Not cheap…….but you often get what you pay for. Considering the cost of new batteries (I have 6), sounds like a wise investment. The positive reviews from u guys @ the forum makes CTEK a no-brainer.
Old May 12, 2024 | 12:06 AM
  #34
JETS C3-C4's Avatar
JETS C3-C4
The "Battery Tender Plus" model are the ones I use 24/7 for over 25 years on all my bikes and cars. Only had one fail and they warranted it and sent me a new one. Like others have said and I also would recommend them. Other brands mentioned seem to have good reviews also. If I need another I will get the Battery Tender Plus model again. I currently have 6 of them and some are 20+ years old.
Old May 12, 2024 | 12:22 AM
  #35
rpoL98's Avatar
rpoL98
one thing I notice when comparing the CTEK and the NOCO product line, specifically the accessories.
NOCO offers an adapter that will mate the NOCO proprietary connector to the industry standard connector used by Battery Tender and others. Allows me to use the battery clamps and 12V extension cables that I already have.
NOCO GC009 X-Connect SAE Adapter Accessory Genius Smart Battery Chargers NOCO GC009 X-Connect SAE Adapter Accessory Genius Smart Battery Chargers
I couldn't find an equivalent adapter for CTEK's proprietary connector on their Amazon page.
ETA: ====================
I went on the Amazon page for Battery Tender.
seems the "Battery Tender Plus" refers to the 1.25A "Powersports" chargers/maintainers.
Battery Tender > Powersports Battery Tender > Powersports
the Battery Tender (not plus) refers to their automotive chargers/maintainers, 3A on up to 15A.
Battery Tender > Automotive Battery Tender > Automotive
seems the "Battery Tender Plus" should be an enhanced version of the "Battery Tender", normal naming convention, but doesn't seem to be the case, at least according to their Amazon storefront.
Old May 13, 2024 | 12:29 PM
  #36
Tech141's Avatar
Tech141
I've used "Battery Tender" for the last 94 years and have never had a problem with them.
Old May 13, 2024 | 01:28 PM
  #37
wwiiavfan's Avatar
wwiiavfan
What conditions are you storing in? I found out the hard way a battery tender (maintainer) will not protect a battery during extreme cold.
I since bring my batteries into the house during the winter with a tender on them.
To Battery charger that's solid and dependable?
Old May 13, 2024 | 02:13 PM
  #38
JETS C3-C4's Avatar
JETS C3-C4
I have vehicles stored both in heated and unheated buildings with the Battery Tenders on them 24/7. I have not had any issues with using the Battery Tenders in the cold. I am in Wisconsin and we do get some sub zero temperatures during the winter months. I have been using the "Battery Tender Plus" model for way over 20 years and as I said in my previous post I had only one that failed which was replaced under warranty and that one was being used in a heated building. The ones I use have a 10 year warranty.
Old May 13, 2024 | 05:27 PM
  #39
rpoL98's Avatar
rpoL98
Since the family started this company in 1965, Deltran Battery Tender® has taken great pride in designing, manufacturing, and distributing technologically advanced products that meet the ever changing needs of our worldwide customers!
Old May 13, 2024 | 06:52 PM
  #40
JETS C3-C4's Avatar
JETS C3-C4
WOW, 94 years you got me beat. LOL
Are you still driving your Vette ?
