72 with HEI plug wire suggestions
Old Nov 8, 2021 | 09:11 AM
Hig116's Avatar
Hig116
Default 72 with HEI plug wire suggestions
I need wires for my 72 that has an HEI distributor and wanted to get everyone's opinion. I have the stock manifold and assume I need to route the wires the way the factory routed them. ALTHOUGH, that is a PITA and I'm not sure it wouldn't be better to route of the top. Of course then I have to worry about heat. Any suggestions on wires and routing? Anyone have any photos of routing over the top with stock exhaust manifold?
Thank you,
Keith
Old Nov 8, 2021 | 09:26 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I use the cut your own 73057 Taylor wire set and their cut/crimp tool......
Refer to this photo of a 66' 327 Impala engine for alternative wiring.......
Jebby
Old Nov 8, 2021 | 10:09 AM
Fly skids up!'s Avatar
Fly skids up!
What isn't a PITA to do on a Vette? It's worth the trouble to run the wires under the manifolds. I just replaced my wires with AC Delco 608D. The fit was perfect with the HEI and wire retainer. In the "1982 MY problems & solutions" sticky you'll find what length wires go were which saves you from a lot of trial and error. You may want to replace the the motor mounts while you're in there. Anchor 2285 is what I used from Rockauto. No fitment issues nether. You also may like to have the spark plug wire grommets on hand too. I wish I did.
Old Nov 8, 2021 | 01:46 PM
wwiiavfan's Avatar
wwiiavfan
Bought these to go under the side pipes headers on my ‘71 350. Plenty long to reach them all. Scoff if you want, but I have 1200 trouble free miles on them so far this summer.
https://www.ebay.com/itm/25315025856...3ABFBM1KHqjaBf
Old Nov 8, 2021 | 02:13 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I like OEM myself. Just like keeping stock.
To 72 with HEI plug wire suggestions
