O-Rings for Caliper Halves
Old Dec 6, 2021 | 11:15 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Default O-Rings for Caliper Halves
Does anyone know the measurements of the small o-rings that seal the caliper halves?
ID?
OD?
One of my '72's front calipers is definitely leaking between the halves. I'd like to obtain the replacements before removing and tearing the caliper down. Why, you ask, don't I seek a warranty replacement? Because I use DOT 5 fluid and I'm sure they won't do anything for me.
Old Dec 7, 2021 | 03:47 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Well, don't have the measurements. Sorry. But most O ring master kits would likely have a suitable replacement. Break one down and run to the auto parts or a good bearing and seal shop. match it up, run home and put it together.
Thinking of course you have alternative transportation.
I too run Dot 5. have for 25 years or more in my 77.
nothing in Dot 5 will destroy that O ring.
Old Dec 7, 2021 | 08:46 AM
Fly skids up!'s Avatar
Fly skids up!
I would recommend rebuilding the whole caliper. You already got it apart.
Last edited by eboggs_jkvl; Dec 7, 2021 at 11:08 AM. Reason: Why do a Joe Biden repair?
Old Dec 7, 2021 | 09:46 AM
barkingrats
Because it's a Lone Star caliper that's only a year old that has never been on the road. Still looks brand new.
Old Dec 7, 2021 | 09:51 AM
barkingrats
Have also run Dot 5, since mid/late '80s, with no problems in my '67. One of the things I've read (though am not sure what to believe any more) is that newer seal materials are not compatible. Zip Products has a blog article about the newer orange hi-temp seals not playing well with silicone fluid. I want to make sure the o-rings I use are EPDM (old school) but haven't checked the local parts stores for composition and am thinking I probably need to order them.
Old Dec 7, 2021 | 10:55 AM
interpon's Avatar
interpon
fyi i warranted 2 front calipers recently from 2 sponsor vendors.. lone star...one at a few months and another 11 months .. one year warranty... both were replaced one even paid shipping..BUT they said if the return is non DOT3 they will not honor warranty.
they did mention the leaks they do get were from poor alignment or missing small o rings leaking from the halves.. mine was from pistons on both
Old Dec 7, 2021 | 05:35 PM
forman's Avatar
forman
I have rebuilt about 20-30 of these calipers always use the raybestos brand rebuild kits USA made the rubber is much softer then other brands
always check the aluminum pucks for ware on the edges and corrosion in the stainless sleeves and replace the bleeders they always seem to crush on the ends and make a bad seal
Old Dec 7, 2021 | 10:15 PM
barkingrats
Huh. Not even DOT 4 or 5.1?
To O-Rings for Caliper Halves
