Steering wheel lock pin/ bolt?
Old Dec 9, 2021 | 01:19 PM
LawN4cr10's Avatar
LawN4cr10
Default Steering wheel lock pin/ bolt?
I’m working on a 1972 standard steering column and seems there may be some parts missing. Should the standard steering column have a pin or bolt attached to the ignition mechanism to lock the steering wheel in place when the ignition is off? I have only been able to find the locking pin for tilt/ tele steering columns. The second part I might be missing but I’m not sure if was an option on the standard steering column is the key warning buzzer contacts. Any help or advice would be appreciated.
Old Dec 9, 2021 | 05:49 PM
Mooser's Avatar
Mooser
I believe they all locked
Everything you'll want and much more can usually be found on Jim Shea's GM steering pages
http://jimshea.corvettefaq.com/
The doc you might want is this one
M
