Rear Spring Question
Old Dec 26, 2002 | 12:00 AM
Bullyj's Avatar
Bullyj
Default Rear Spring Question
The other day I had the wheel off so I counted the leaves I count 10. I've seen some post that mention 7. What the difference, is one better than the other?
Old Dec 26, 2002 | 12:15 AM
Paul L's Avatar
Paul L
Default Re: Rear Spring Question (Bullyj)
The former is stock (9-10) and the latter is the FE7 option: much stiffer. The FE7 is 2 1/4" wide and the stock the same until 1978 when it was widened to 2 1/2". What is better depends on how fast you take corners.
