1972 LT-1 A/C compressor
Old Dec 13, 2021 | 04:29 PM
chris383's Avatar
chris383
Default 1972 LT-1 A/C compressor
Hi,
I want to replace my original A/C A6 compressor with a new one. Most new units (like Alma for example) have a 5'' pulley diameter.
My original one have a 5.75"pulley. Why there are 2 different types ? What is the technical difference ? I guess maybe a 5.75 is better for high rpms like the LT-1 is capable ?
Thank you in advance.
Chris
Old Dec 13, 2021 | 05:22 PM
REELAV8R's Avatar
REELAV8R
That would be my guess as well. Larger diameter to handle higher RPM's. But really who is going to have the A/C on while turning 6500 RPM? It would also reduce the effort required by the engine, perhaps for low RPM (idle) when it's not making much power.
From reading I've done you're better off rebuilding the current compressor vs a replacement. Usually the only thing wrong is the front seal leaks.
Old Dec 14, 2021 | 04:07 PM
chris383's Avatar
chris383
My problem is that I had already given my compressor for a rebuild (here in Switzerland) and my clutch is now broken....
I would rather buy a new one instead of trying to fix my clutch and have another problem later!
Old Dec 14, 2021 | 04:59 PM
REELAV8R's Avatar
REELAV8R
The clutch can be replaced without replacing the entire compressor.
rebuild or new A6 compressor quality is questionable. If it were mine I’d just replace the clutch if it’s otherwise functioning normally.
Old Dec 14, 2021 | 10:30 PM
PJO's Avatar
PJO
Veteran: Marine Corps
I think 1972 LT-1 with A/C the Tack red line was 5600 RPM. Non A/C was 6500 RPM.
Old Dec 15, 2021 | 07:10 AM
chris383's Avatar
chris383
Yes, I know that it is possible to change only the clutch. I don't know if the clutch was broken by the compressor... Now, it rotates freely by hand (it is not blocked).
Exact : the LT-1 A/C tach is 5'600 and W/O is 6'500.
Old Dec 15, 2021 | 01:22 PM
REELAV8R's Avatar
REELAV8R
So the redline on an a/c version was specifically restricted due to the a/c compressor, or are there other differences?
Old Dec 15, 2021 | 06:56 PM
PJO's Avatar
PJO
The restriction was only due to the A/C compressor belt and it's likely hood of being thrown at high RPM. If you remove the belt then just like standard LT-1 for RPM.
Old Dec 16, 2021 | 12:45 PM
chris383's Avatar
chris383
My engine can easily go up to 5'500 rpm and I think a bit more is also possible...
And for originalty of LT-1 A/C (which is for me important), I'll stay with a 5.75" pulley id possible.
It is quite difficult to find a new compressor with this pulley...and they cost about $ 600 :-(
Alma seems to be good (with some improvments).
Old Dec 17, 2021 | 02:47 PM
REELAV8R's Avatar
REELAV8R
I guess it depends on belt technology then. I regularly run my 77 up to 6300 RPM and have never thrown the belt off the A/C.
Old Dec 17, 2021 | 02:52 PM
REELAV8R's Avatar
REELAV8R
Unless you're looking for originality I wouldn't worry about the diameter of the pulley and just don't run the A/C when reving it high.
Like I said run mine to 6300, no problems. I don't have the A/C running when I do it though. Originally a 5200-5250 redline motor in the 77. Never changed the A/C compressor, still a stock unit.
Old Dec 18, 2021 | 11:58 AM
68/70Vette's Avatar
68/70Vette
My understanding is that the AC compressors for Corvettes was modified by dishing the A6 pistons to produce a lower compression ratio. This slightly reduced their cooling capacity and parasitic drag.
The A6 compressors used a wobble plate...three pistons on one side of the wobble plate and three matching on the other side. Correct? The Germans before wwII built a wobble plate aircraft engine. It is, or was, on display at the Air Force museum in Dayton, Ohio.
Old Dec 19, 2021 | 10:21 AM
chris383's Avatar
chris383
I agree that the belt tech is important : I had AC Delco belts previously and they jumped off the pulleys very easily. With now Dayco belts, no problems anymore !
6'300 rpm with 5'' pulley, I assume ? Good to know because I don't go until that (maybe 5'500 rpm ?). This means I would be able to buy a new Alma compressor with a good price.
Old Dec 19, 2021 | 11:01 AM
REELAV8R's Avatar
REELAV8R
Sure whatever the stock v belt pulley size is on the R4 compressor for the 77. It's just not anything specific for high RPM is all I'm saying. I can also tell you to not buy a gates belt either. It's too stretchy and will fly off at high RPM.
I'm using Bando brand belts and have never had any issues with them at all, durable and last a long time.
This is the exact one I have now.
Amazon Amazon
Old Dec 20, 2021 | 12:35 PM
chris383's Avatar
chris383
Thank you for the information : I didn't know this brand of belts.
$i think now the best solution for me is to buy a new Alma compressor with a 5'' pulley.
Old Dec 20, 2021 | 06:02 PM
novadoug's Avatar
novadoug
Navigator
isn't there a wot switch on accelerator or is that on newer cars ?
Old Dec 21, 2021 | 01:45 PM
REELAV8R's Avatar
REELAV8R
Belt and pulley is still gonna spin the RPM, that WOT switch on newer vehicles disengages the compressor.
To 1972 LT-1 A/C compressor
