Fan clutch Replacement
Old Dec 13, 2021 | 09:38 PM
mbp's Avatar
mbp
Default Fan clutch Replacement
Hello, looking for advice. I believe the fan clutch on my 69 needs to be replaced. The shaft appears to always have some oil on the shaft so I assume that whatever is suppose to stop from leaking out has developed a weak spot and is allowing the oil the leak out. It is a Schwitzer style if that makes any difference. So my question is what should I replace it with? A Schwitzer style or an Eaton style that is also available. As they do the same thing I wondered if one was more reliable or preferred over the other one? Thanks in advance.
Old Dec 13, 2021 | 09:48 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Check out Hayden fan clutches. They are quality pieces.
Old Dec 13, 2021 | 10:56 PM
interpon's Avatar
interpon
I don’t know if one is better than the other but thought maybe the style of the temperature coil.
I personally fixed mine and put it back on.
i would find one with exact measurements as your old one and holes not slots for bolts. I did not like how the bolts were on the slots..
here is my education
https://www.corvetteforum.com/forums...re-79-l82.html
Old Dec 14, 2021 | 07:43 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The Hayden thermo clutch is a good one......Rock Auto has them....
Jebby
To Fan clutch Replacement
