Harmonic balancer installed and timing mark question
Old Dec 28, 2021 | 11:08 AM
  #41
stingr69's Avatar
stingr69
Fuel pump racket? Worth Look.
Old Jan 1, 2022 | 02:17 PM
  #42
riverwabbit703's Avatar
riverwabbit703
Originally Posted by 67:72
Glad to hear the timing is good and a non-issue now.
When you say the blade moves, do you mean you can feel/see it in the fan clutch shaft? That's not usually a very good characteristic...
omg you will not believe what caused that dull ticking noise. Almost lottery odds. Vacuum cap fell of somehow hit few parts on the way down, while engine was idling at 750, pulley turning, half of the belt covered crank pulley and vacuum cap got stuck on the pulley rib. What are the odds. Removed the cap, noise gone. Nice way to start a new year. Happy new year everyone.
Old Jan 1, 2022 | 03:58 PM
  #43
lionelhutz's Avatar
lionelhutz
Nice find. I've never seen that one before.
Old Jan 1, 2022 | 08:26 PM
  #44
kossuth's Avatar
kossuth
you can put the distributor in at any point on the compass. as long as you can find cyl 1 at tdc, you can put the plug wires on so it will time up correctly. makes more sense to set it up with 1 and 2 in the front but it will run wherever it is set up correctly. you made it sound like apparent timing was moving around. that is why i asked about key in crankshaft.
DITTO..... That's why it is so important to know what true 0 is on the balancer vs TDC on the number 1. Wouldn't have been the first time that:
1. A balancer has slipped.
2. A previous Bubba mechanic restabbed the motor just any old way. Traditionally the number 1 is at the 11 o'clock and the 8 is at the 1 o'clock on the dizzy looking from back to front, but it will run any old way as long as you match up a distributor post with the rotor and the appropriate plug wires.
Old Jan 2, 2022 | 05:51 AM
  #45
Budryzer's Avatar
Budryzer
Incredible find!!!!!! Buy a lotto ticket!
Old Jun 9, 2022 | 04:19 PM
  #46
carriljc's Avatar
carriljc
Thanks for this info. I rotated my crank back and forth to install the flexplate and lost track....now I'm out of whack. This looks like the simplest solution.
quicky TDC check since valve covers are off. rotate engine past the TDC mark. look at the valves on #6 and #1 cyls. the exhaust is just closing and intake is just opening right at TDC on either cyl. one or the other cyl. the other cyl is at compression-firing at the same point. this is not dead-to-rights, but it will tell you if you are close.
