TH400 Soft Shifts
Old Dec 21, 2021 | 11:06 AM
Eric-'s Avatar
Eric-
Default TH400 Soft Shifts
Good morning everyone.
I'm having an issue with my TH400.
I've replaced the vacuum modulator and cranked it up a bit to firm up shift points but I am still shifting pretty soft.
So, here I am, hoping to get some advice on what I should be looking at next?
I do hope that my tranny isn't just worn out and in need of a rebuild.
Thanks for your help.
Eric
Old Dec 21, 2021 | 11:14 AM
caskiguy's Avatar
caskiguy
This may help.
https://www.motortrend.com/how-to/hp...ting-turbo-400
Old Dec 21, 2021 | 11:42 AM
Eric-'s Avatar
Eric-
Originally Posted by caskiguy
Thank you for the information, I'll have a read.
Old Dec 21, 2021 | 06:31 PM
Eric-'s Avatar
Eric-
I should attempt to be more specific.
Under normal driving conditions I don’t really notice any problem.
When I’m giving it some gas, or under wide open throttle that is when it is most noticeable.
It is a very soft, long, shift. Couple days ago I was driving and thought for a minute it wasn’t going to shift at all from second to third. It really wound up before shifting.
Old Dec 21, 2021 | 07:41 PM
How Are You's Avatar
How Are You
Do TH400's run a vacuum hose that could be leaking?
Old Dec 21, 2021 | 08:04 PM
Jeffs82c3's Avatar
Jeffs82c3
Yes they do have a vacuum line, go’s to the carb. Also a electric solenoid to control full throttle downshifting.
Old Dec 21, 2021 | 08:13 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
rpm shift is governor.
strength of shift,,,
pump pressure
worn bands
sticky worn valve body.
Shift kits with springs, different valve body gasket, ***** will apply more pressure to the shift actuation.
To TH400 Soft Shifts
