I am completing the recurve of my 80 L48 dist. timing and I need to get manifold vacuum to the distributor vacuum can. I believe I can get the vacuum from the rear port as shown in the photo (yellow line). But what do I do with all the other lines (green lines) that seem to be controlling the air cleaner ducts? Where should I connect them, to be still operational?
Select a vacuum line that has suction at idle and above, cut it, insert a T and connect the distributor to it.
Yes it is manifold vacuum. it has vacuum at idle. The original green line that goes to the dist does not have vacuum at idle, It comes from a TVs switch
Ok thanks Mel so I should T into the yellow line and then connect the Existing green line into it also?
just cap the original distributor tap off the line. It's part of the Early Fuel Evap system for fast warm ups. You are bypassing that system as far as the vacuum advance is concerned.
To me it looks like the DISTR TVS switch supply line is RED and on a 77 where it is connected to the carburetor vacuum nipple is Full Manifold Vacuum, not ported.
If you disconnect the RED vacuum line on your carburetor do you have vacuum at idle?
If so, just get a length of vacuum hose long enough to connect carb to vacuum advance can bypassing DISTR TVS switch completely.
