Idler arm torque?
Old Jan 3, 2022 | 12:11 PM
mbp's Avatar
mbp
Default Idler arm torque?
Hello. I will be reassembling my relay rod and idler arm. I looked in the A.I.M. but I can't find the torque spec for the castle nut that attaches the idler arm to the relay rod. Any help would be appreciated. Thanks and take care.
Old Jan 3, 2022 | 01:17 PM
PJO's Avatar
PJO
Veteran: Marine Corps
Pitman Arm to Control Valve 35-47
Outer tie rod to spindle 35-47
Center Link to Idler Arm 50-70 Then align cotter key slot to hole.
Pitman Arm to Center Link 35-47
Inner tie rod to center link 35-47
Pitman Arm to Sector Shaft 150-225
Idler Arm Bracket to Frame 30-40
Tie rod connecting sleeve bolts 9-15
Old Jan 3, 2022 | 02:00 PM
mbp's Avatar
mbp
Thanks for the numbers. Were they in the AIM, or did you get them elsewhere? Thanks again.
Old Jan 3, 2022 | 02:06 PM
PJO's Avatar
PJO
Shop manual.
Old Jan 3, 2022 | 03:25 PM
mbp's Avatar
mbp
Shop manual.
Hello again, sorry I should of mentioned it was a 69, if it makes a difference. Are those numbers the same on a non power steering as a power steering? Just curious.
Old Jan 3, 2022 | 03:59 PM
PJO's Avatar
PJO
It was for a 1970 but the steering linkage was the same. Would torque to 35 lb.ft. then tighten to match castle nut to hole. That is why the 35 lb.ft. to 47 lb.ft. to allow for alignment of nut.
To Idler arm torque?
