77 Clutch rod hole
Old Jan 9, 2022 | 04:03 PM
Gordonm's Avatar
Gordonm
Default 77 Clutch rod hole
Doing a 5 speed conversion with a hydraulic TO bearing. This car was an automatic and the older C3 cars used to have a plate over the clutch rod hole. Not so in the later C3 cars. I have a pretty good idea where the hole should be but if anyone has a picture for a little more reference I would appreciate it.
Old Jan 9, 2022 | 04:20 PM
bmotojoe's Avatar
bmotojoe
This 5 speed conversion was done on a early 77...
LINK:http://www.corvettec3.ca/tko.htm
Old Jan 9, 2022 | 05:05 PM
Gordonm's Avatar
Gordonm
I remember that write up from years back. Just needed a reminder. The car was up on the lift and I was working from the engine side and no sign of the hole. Climbed in the car and pulled back the firewall insulation and guess what I found. The hole location. Just have to take a holesaw and drill out the fiber glass. The 3 bolt holes are also there with just pin holes.
Thanks for the nudge in the right direction. Problem solved.
To 77 Clutch rod hole
