Exhaust and headers
Old Jan 13, 2022 | 07:22 PM
PennyJack's Avatar
PennyJack
Default Exhaust and headers
I have a 68 automatic 327.
What kind of exhaust and headers do you all recommend with out breaking the bank?
Old Jan 14, 2022 | 12:02 AM
Cmurray79's Avatar
Cmurray79
Corvette central has complete exhaust kits that fit well. Just know what diameter pipe you want and look through the options for your year. Headers all the way to mufflers
Old Jan 14, 2022 | 03:20 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
The problem with your question is the last part about breaking the bank.
Lots of guys on here happy to spend your money.
But we have no idea of the size of your bank.
If it's like my bank. Then wrapping over the holes with old soup cans and hose clamps will have to do.
If you have a bit more than me.
Ceramic coated long tube headers and a 2 1/2 inch exhaust system with a X pipe and your choice of mufflers.
I run the Chambered exhaust. It sounds wonderful!
(Read loud).
give us an idea of the bank in question.
Perhaps we can help more.
Old Jan 14, 2022 | 08:38 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
If you do not have the budget for ceramic coated headers.....don't buy anything til you do. Vette's hold a lot of heat underhood......uncoated headers add to this greatly. There is about a 300 degree difference between coated and uncoated at the tube.
For C3's I prefer the Hedman brand......I have had better luck.
For exhaust....I like the Wilcox chambered system......I installed one years back on a 69' and it fit perfect and sounded awesome......
Jebby
Old Jan 14, 2022 | 08:47 AM
randallsteel's Avatar
randallsteel
I have found that summit racing brand headers(get the ceramic coated ones) are a good fit, hold up well, and are more affordable than many other headers.
Old Jan 14, 2022 | 01:18 PM
TedH's Avatar
TedH
Need the bank balance...
Ceramic coated headers and custom bent duals and mufflers with h- or x-pipe and you are probably looking at $1,000-1,500. If you can get a complete set, you may save some $$$.
Old Jan 14, 2022 | 01:24 PM
caskiguy's Avatar
caskiguy
https://www.southwestspeed.com/?sec=...0Block%20Chevy
Bought my ceramic coated headers from here, nice. https://www.southwestspeed.com/?sec=view_part&id=40440
Btw, Rack and pinion conversion fits.
Old Jan 14, 2022 | 02:09 PM
TedH's Avatar
TedH
Wow. Stainless is only $50 more than ceramic coated. For that price, I'd go stainless. Granted it won't cut the heat but it also won't rust.
Q: Where are these manufactured?
Old Jan 14, 2022 | 02:44 PM
caskiguy's Avatar
caskiguy
Q: Where are these manufactured? I have no idea.
Good luck
Old Jan 15, 2022 | 12:22 AM
4-vettes's Avatar
4-vettes
Stainless is also more prone to cracking. Really depends on the thickness and quality of the Stainless.
Ceramic coated also will not rust as long as it doesn't get damaged. And it will hold in the heat.
If the Ceramic coated where 50 dollars more. I would still buy the Ceramic coated.
Just my 2 cents.
To Exhaust and headers
