Windows not working
Old Jan 16, 2022 | 09:09 PM
Aj37's Avatar
Aj37
3rd Gear
Default Windows not working
77 Both windows not working suddenly. Have power to the relay
Old Jan 17, 2022 | 02:11 AM
caskiguy's Avatar
caskiguy
I'd just start from square 1 and check everything in between.
Good luck
http://repairs.willcoxcorvette.com/c...e-power-window
https://www.corvetteforum.com/forums...ce-needed.html
and little information never hurts: https://tech.corvettecentral.com/201...ric-windows-c3
https://www.corvettemagazine.com/196...or-replacement
Old Jan 17, 2022 | 03:10 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
You have power to the relays, sounds like you know how to test for power. Keep going.
Old Jan 20, 2022 | 11:56 PM
Puniphorous's Avatar
Puniphorous
Mine failed at the connector on both window motors. I used Deoxit on both connectors, and tightened the grip for the spade connectors. Problem solved.
Old Jan 21, 2022 | 03:46 AM
ukjohn's Avatar
ukjohn
You say you have power to the relay, do you have power coming out of the relay when the ignition is on?
To Windows not working
