'73 Air Conditioning Removal Question
Old Jan 27, 2022 | 05:59 PM
OldCarBum's Avatar
OldCarBum
Default '73 Air Conditioning Removal Question
As part of the restomod on my '73 big block I'm removing the oem air conditioning and replacing it with a new Vintage Air system.
I'm getting ready to start removing the compressor, condenser and all the existing lines.
The prior owner told me the air conditioning did not work the entire time he owned it, and I haven't used it in the past 6 years.
My question is:
How do I make sure there is no pressure in the system before I start removing everything?
Is there a pressure release valve or a safe way to release any pressure in the system?
I don't want to just start loosening fittings and opening lines that might be under pressure.
Thanks.
Old Jan 27, 2022 | 06:04 PM
AKjeff's Avatar
AKjeff
There should be a schrader valve somewhere on the system that you could briefly depress to check for pressure.
There may still be gas in the system and there was another problem that kept it from working.
I might go so far as to go to an auto shop and see what they'd charge you to evacuate the system. If they have the equipment to recycle the R12 they may do it for free.
Old Jan 27, 2022 | 06:38 PM
OldCarBum's Avatar
OldCarBum
There is a Schrader valve next to the compressor and I was going to start there.
I just wasn't sure it would discharge the entire system.
Right now the car is up on blocks and being disassembled.
Thanks!
Old Jan 27, 2022 | 06:49 PM
AKjeff's Avatar
AKjeff
It should discharge the entire system.
Wear safety glasses, gloves, bla bla bla. A short burst of freon shouldn't hurt but it can freeze/burn your skin if a stream of it from the schrader is in contact for long.
Old Jan 27, 2022 | 07:19 PM
derekderek's Avatar
derekderek
don't worry. there is no pressure in there...
Old Jan 27, 2022 | 07:29 PM
OldCarBum's Avatar
OldCarBum
Thanks!
Old Jan 27, 2022 | 07:30 PM
OldCarBum's Avatar
OldCarBum
Maybe not, but with my luck....
Old Jan 28, 2022 | 07:08 AM
Mr D.'s Avatar
Mr D.
Depress the schrader valve and if nothing comes out go forth and remove the system OR just crack a line and let the system depressor itself. My bet is nothing in the system to worry about.
Old Jan 28, 2022 | 07:42 AM
DWAVette's Avatar
DWAVette
Don’t forget to get ready for oil to come out of the lines also. The compressor is lubricated by small amounts of oil flowing with the Freon. Oil, unless it all blew out, will likely be collecting in the compressor and accumulator/dryer. No big deal. But if you don’t want an oily mess on the ground, have some rags handy.
The lines and evaporator are probably not useful, but another forum member may have use for the compressor and condenser. An NCRS competitor may want them.
Old Jan 28, 2022 | 08:24 AM
interpon's Avatar
interpon
and if there was of any amount.. i wouldn't be changing it out !!
Old Jan 28, 2022 | 08:30 AM
Tampa Jerry's Avatar
Tampa Jerry
How about using a vacuum pump and a set of gauges. They are fairly inexpensive from Harbor Freight. Jerry
Old Jan 28, 2022 | 11:56 AM
OldCarBum's Avatar
OldCarBum
I agree with all the above that there is probably no pressure in the system.
Thanks for the tip regarding the oil and having rags ready.
Once I get it all removed, I will be putting it up for sale.
I believe it is all original.
To '73 Air Conditioning Removal Question
