Door Switches
Old Feb 3, 2022 | 05:30 AM
chuckwp's Avatar
chuckwp
Default Door Switches
I got these door/courtesy switches from Zip Corvette. The "door ajar" ones are the same configuration. I have not seen a door switch like this with a plastic thing on the end. So, how is the ground wire supposed to connect?
What am I missing? Doing a complete rewire with an AAW kit so, I can do whatever is needed. I do not have the original switches to compare what they looked like or, how they connected. Every other GM door switch I have seen either has a mini spade or, barrel type connection.
Old Feb 3, 2022 | 06:41 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
No ground wire. they ground through the body of the switch directly to the door frame. Remove the plastic shipping protector and white wire should plug onto the end.
Nothing more.
Old Feb 3, 2022 | 06:46 AM
chuckwp's Avatar
chuckwp
Nothing more.
Yeah I know that the ground is through the frame but, the wire that grounds the light circuit attaches to the switch. That is not a shipping protector on the switch it is part of the switch plunger and does not come off.
Old Feb 3, 2022 | 06:54 AM
4-vettes's Avatar
4-vettes
Looks like this installed. Plastic protector has to come off to connect wire.
Old Feb 3, 2022 | 07:19 AM
69ttop502's Avatar
69ttop502
These are the terminals that connect the wires to those switches. All the vendors sell these. You are right, that is not a plastic protector and does not come off!
https://www.ecklers.com/1968-1974-co...iABEgKPw_D_BwE
Old Feb 3, 2022 | 07:29 AM
Mooser's Avatar
Mooser
Missing the contact points
DON'T take that plastic piece off or you'll look at buying a new one
M
Old Feb 3, 2022 | 09:16 AM
chuckwp's Avatar
chuckwp
That is the answer! Thanks
M
Old Feb 3, 2022 | 09:17 AM
chuckwp's Avatar
chuckwp
Thanks!
Old Feb 3, 2022 | 09:20 AM
hunt4cleanair's Avatar
hunt4cleanair
What year are you describing? There were spade-style switches and pin-style switches...sounds like you're working to install a spade style in a pin-style configuration. In 73-74, began to use the spade style. The two pages are from the NCRS tech manuals 73-74 and 75-77...see if this helps.
File Type: pdf
File Type: pdf
Old Feb 3, 2022 | 09:23 AM
Mooser's Avatar
Mooser
That's great info there (don't have one that covers the 72 do you?)
M
Old Feb 3, 2022 | 09:46 AM
hunt4cleanair
M
It just says they are the SX switches...pin style
Old Feb 3, 2022 | 09:51 AM
Mooser's Avatar
Mooser
I think that's all I ever found as well so at least it's consistant
Thank
M
To Door Switches
