Center gauges not working
Old Feb 6, 2022 | 02:18 PM
psycho dad's Avatar
psycho dad
Default Center gauges not working
So, my gauges were all working last year when I removed the dash panels on my '76. Now that everything is back together, the water temp, battery and oil pressure gauges aren't working.
I suspect a ground issue, anyone have a suggestion?
Old Feb 6, 2022 | 02:58 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
ground is the usual trouble
Old Feb 6, 2022 | 04:19 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Sounds like you need to pull it all back apart and check all your connections. Always check things like this as you go! Nothing worse than getting it ALL back together and find part 1 isn't right.
Old Feb 6, 2022 | 04:29 PM
Fly skids up!'s Avatar
Fly skids up!
A quick way to know if it's ground or power is to see if the alternator light comes on, if it does it's ground.
Old Feb 6, 2022 | 04:41 PM
Fly skids up!
Double post
Old Feb 6, 2022 | 04:43 PM
psycho dad's Avatar
psycho dad
Tell me about it.
No Alternator light.
​​​​​​​Are they grounded to the console, or should I be looking for a wire somewhere?
Old Feb 6, 2022 | 06:10 PM
Fly skids up!
Well unless there's a problem with the charging system it's likely it's power to the center instrument cluster. If it was a ground problem the gauges would do something until you turned on the parking lights.
To Center gauges not working
