Fuel gauge
Old Feb 6, 2022 | 08:28 PM
Johng823's Avatar
Johng823
Cruising
Default Fuel gauge
Is there a simple test for a beginner to determine if the fuel sender or the gauge itself is bad?
Old Feb 6, 2022 | 11:27 PM
thatcorvetteguy's Avatar
thatcorvetteguy
Touch the sender wire at the gas tank to ground and look if the fuel gauge moves. If it does you have a bad sender.
Old Feb 7, 2022 | 03:35 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Um, there is a connector up in the left hand quarter panel that connects the fuel sender. Get your head up in the left rear quarter panel. It's a 2 wire connector. one is ground the other the sender wire. The ground will be black , the sender is tan or light brown by memory.
Connect the tan wire on the side going to the gauge to a good ground. Watching your gauge as you do it. (or have a helper) Sender can be checked off the other side of the connector with a ohm meter and a friend hooking and raising the float. 90 ohm sending unit.
Old Feb 7, 2022 | 09:47 AM
Hopper12's Avatar
Hopper12
Hey John, Welcome to the forum! This should help: https://redirect.viglink.com/?format...-gauge-info%2F
Old Feb 7, 2022 | 08:00 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Go to the Willcox trouble shooting pages. Doc rebuild has some tests as well
http://repairs.willcoxcorvette.com/w...it-testing.pdf
http://repairs.willcoxcorvette.com/c...el-gauge-info/
To Fuel gauge
