Remove caliper bolts
Old Feb 28, 2022 | 09:20 PM
tehjrow's Avatar
tehjrow
Default Remove caliper bolts
I took a shot at removing my rear calipers so I can drill out my rotor rivets to eventually overhaul my e-brake. The bolts are so hard to get to because the hard brake line is like right in the way. I can get a socket on the top bolt but can't get a ratchet on it because of the line and I can't even get a socket on the bottom one. Do people remove the brake lines? Is there a trick I don't know?
Old Feb 28, 2022 | 09:58 PM
kansas123's Avatar
kansas123
There may be a way. I don't remember what year your car is
Old Feb 28, 2022 | 09:59 PM
tehjrow's Avatar
tehjrow
Old Feb 28, 2022 | 10:01 PM
Bikespace's Avatar
Bikespace
I use an offset wrench for that specific bolt (5/8").
Old Feb 28, 2022 | 11:10 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
You can gently bend the lines a small bit to aid getting to the bolt heads... or, just remove the hard lines from the calipers and hose connections and know you'll have to bleed the brakes later on. As I recall, I've had to use a short (3"ish) extension on the socket so the ratchet head will clear the trailing arm and caliper housing.
Old Mar 1, 2022 | 12:29 AM
AKjeff's Avatar
AKjeff
Mine were so tight I needed a breaker bar and cheater.
I was able to fit a 3/8 extension and socket past the hard line, then adapt it to a 1/2" breaker bar.
Old Mar 1, 2022 | 08:31 AM
interpon's Avatar
interpon
yes, i have to remove mine..a good time to buy a new steel line as well.
I am sure it can be done as others say, but i have not found a way. Very hard to get back in too..
i think on mine i even have to remove the rear sway bar bracket but it's been a while.
wont have caliper hanging around either. leaking? time for a rebuild?
https://www.corvetteforum.com/forums...82-please.html
To Remove caliper bolts
