Hi all! My 1980 L48 has no Spark. Replaced module, cap and rotor. I'm getting 12v at distributor and rotor is turning. Wiring looks OK .
Bench tested coil and results are as follows
Primary resistance is .2 ohms
Secondary is 35.53 ohms.
Any ideas would be greatly appreciated...
Check the hall effect pickup "coil"......this tells the module to fire the coil......and was the second most common HEI failure......
I won't replace them anymore unless the customer HAS to have their original distributor.......I usually stick a 906 GM crate engine HEI. GM (General Motors) - 93440806 - HEI Performance Distributor (paceperformance.com)
But you pay me the same money to put a pickup coil in a 40+ year old distributor or stab this new one in.......the crate distributor has a much better curve.
I will assume that when you swapped-out caps you checked the little spring & rubber washer in the bottom of the cap before you installed your old coil?
Remove the dust cover. On one corner of the coil, a black wire is attached or should be attached to one of the four hold-down bolts. If the coil has excess paint on the metal, remove that down to bare metal. Reattach GRD wire.
Where the wire harness attaches to the side of the cap, Yellow, Red, Black wire clips, can sometimes show false illusion of a good connection.
Perhaps clean contacts and apply a dab of dielectric grease.
Have you tested the pickup winding? New Module junk? Test coil by snapping the signal wire (yellow or white) to ground?
I have not tested the winding. Just replaced module in November and it ran good till now. Just put another one in last week. I'm hoping it's good.
I will check the wiring. Thanks
