Torques for Upper Control Arm Shaft Bushing Bolts
Old Mar 13, 2022 | 01:00 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Default Torques for Upper Control Arm Shaft Bushing Bolts
The AIM for my '71 isn't clear to me on this.
Page 3-A2 shows that the LOWER Control Arm Shaft end bolts should be torqued to 45-55 LBS-FT with a note to tighten with suspension compressed to height at which geometry is set.
However there is no such data for the UPPER Control Arm shaft end bolts. Am I correct to assume that the values & note should apply to BOTH upper & lower control arm shafts??
Paul
Old Mar 13, 2022 | 07:56 AM
sw69vette's Avatar
sw69vette
Yes , I used the same torque specs on both upper and lower control arm bushing end bolts on my 69 .
Old Mar 13, 2022 | 09:01 AM
interpon's Avatar
interpon
45-55 foot pounds for 79..and it sure seemed like a lot on that size bolt.
on my tight area on upper could only get a small wrench on the fronts so they are finger bruised tight.
Old Mar 13, 2022 | 09:44 AM
Mooser's Avatar
Mooser
The arms were supplied as assemblies which is why they don't call out the bolts / torque like "normal"
Remember to tighten with the suspension at ride height
I also couldn't get a torque wrench onto the front-passenger bolt so tighten the crap out of it (and loctite)
M
Old Mar 13, 2022 | 10:02 AM
hornetball's Avatar
hornetball
C2 has basically the same suspension. 1963 Service Manual has 45-55 for the lower end bolts (page 3-11) and 35-40 for the upper end bolts (page 3-12).
Old Mar 13, 2022 | 10:18 AM
Mooser's Avatar
Mooser
FWIW, 72 Chassis manual had the uppers at 60, AIM was 45-55 ft-lb
With loctite and new bolts I went 45 on a clicker everywhere I could
M
Old Mar 14, 2022 | 06:06 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Thanks-you Interpon. I see that page also just references the lower shaft end bolts (Z & 4) - nothing for the upper shaft
M
M
Thanks Mooser, surprised there was a difference between the AIM and Chassis Manual.
Thanks - Maybe they found the different torques for upper & lower weren't really necessary and they just went with a common value for the C3s. I guess it can't hurt to use a bit less on the uppers. At least it may be easier to see if any of the upper bolts start to back out...
Thanks again all!
To Torques for Upper Control Arm Shaft Bushing Bolts
