Rubber Fuel line Hose replacement
Old Mar 13, 2022 | 02:16 PM
C3FIXER's Avatar
C3FIXER
Default Rubber Fuel line Hose replacement
How do I replace my 45 year old rubber hoses that are attached to the fuel pump without draining my gas tank? I have purchased the new hoses as a safety precaution.
Old Mar 13, 2022 | 02:59 PM
HeadsU.P.'s Avatar
HeadsU.P.
This is where a pair of ramps is a God send. And every C3 owner should have a pair. Faster, safer, than floor jacks & jackstands.
With your car up on ramps this puts the pumps fuel lines higher than the gas tank sender unit. It should not drain on you.
I assume you purchased the pre-formed "S" hose also. Do one hose at a time at the pump to avoid mistakes.
A stainless steel worm-drive hose clamp works so much better than the factory style spring clamp.
Old Mar 13, 2022 | 03:08 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Good advice here. Have a receptical underneath to collect any fuel drips, accidents, etc. You definitely want the proper S shapped hoses.
Old Mar 13, 2022 | 05:23 PM
interpon's Avatar
interpon
And be prepared for spilling gas..no matter the method..prepare for worst.
i pinched the new line and slipped off old quickly put new on with pinch until ready for other end..
there is a surprisingly lot of fuel in feed line to carb and pump etc..
To Rubber Fuel line Hose replacement
