Excellent header gaskets.....
Old Mar 14, 2022 | 09:39 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Default Excellent header gaskets.....
I recently had to retorque heads on a 406 due to the engine builder installing head studs dry with not lube on the threads....yeah, I know. The 80' Vette has Hooker side exhaust and they leaked pretty bad.
The previous setup was cheap 3/4" header bolts and unknown manufacturer graphite header gaskets.
I replaced them with a stud kit and these:
http://catalog.remflex.com/CHEVROLET...ket_p/2005.htm
Awesome crush and cover the square Hooker ports perfectly.....
If you are looking for header gaskets for your sidepipes.....these are the ones.
Jebby
Old Mar 14, 2022 | 09:44 AM
djquik1's Avatar
djquik1
Very nice, been looking for good exhaust gaskets for a while
Old Mar 14, 2022 | 09:47 AM
HeadsU.P.'s Avatar
HeadsU.P.
Your endorsement check,
is in the mail.
Old Mar 14, 2022 | 09:49 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
is in the mail.
I'll take a bottle of Crown instead....
Jebby
Old Mar 14, 2022 | 09:52 AM
REELAV8R's Avatar
REELAV8R
When I bought my hooker headers and had them coated from Jet Hot they sent gaskets with them. Some kind of graphite/metal looking type material. Looks similar to what you are linking. I did have to port them a little larger for the AFR heads is all.
I've never had to replace those gaskets. Taken the headers off a couple time as well.
I believe the secret is to make sure the header bolts stay tight. Whatever way you accomplish that.
I used stage 8 bots and modified the locking clips a little to fit next to the pipes. Put the bolts on and tightened then used the car a few times re-tightened them and installed the locking clips. No leaks after 10 years+
Old Mar 14, 2022 | 09:58 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Studs work well for me.....and it make sense if you pay attention to how a stud/nut clamps it down......
A lot of people have problems with this and there are many answers.....but the studs and these gaskets are a damn good solution. It is tough to find a good gasket for the Hooker square port.....the port is so big that it is thin along the edges on a Fel Pro or equivalent....blow out easy there even if they are tight.
Jebby
Old Mar 14, 2022 | 11:32 AM
REELAV8R's Avatar
REELAV8R
Jebby
The ones I have now are very similar to these, may even be these. There were no markings on them so I'm not sure who manufactured them.
Amazon Amazon
Old Mar 14, 2022 | 01:03 PM
Stormin_Normin's Avatar
Stormin_Normin
Good to know, I had a heck of a time sealing my doug's side dumps.
Old Mar 14, 2022 | 02:43 PM
pspicci's Avatar
pspicci
i have been using remflex for about 3 years now on my 496 and they are the best i've used. especially if you have surface irregularities they are thick enough seal less than perfectly flat mating surfaces.
Old Mar 15, 2022 | 11:56 AM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
Jebby
Been using Remflex for a long time. Just got some for my D port alum GM heads and they match perfect.
Always enough meat to seal.
Old Mar 15, 2022 | 01:24 PM
OMF's Avatar
OMF
Jebby
You should try Forty Creek.....very nice!
Old Mar 15, 2022 | 02:07 PM
Kerschmolar's Avatar
Kerschmolar
Remflex solved my repeating header leak.
But, be careful they break easily! One accidentally slipped out of it’s packet while opening and broke when it hit the floor.
Old Mar 16, 2022 | 10:30 AM
scottyp99's Avatar
scottyp99
I'm thinking about using a Remflex gasket on a new aluminum head, how do you guys like to install them? Just dry or with some sort of dressing?
Scotty
Old Mar 16, 2022 | 12:45 PM
Kerschmolar
Dry; they start out thicker and crush into place.
Old Mar 16, 2022 | 01:32 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
The Remflex is the best I have found since Earl's stopped making their version called Pressure Master.
To Excellent header gaskets.....
