1971 Tire Pressure
Old Mar 18, 2022 | 09:36 PM
jbakyy's Avatar
jbakyy
Default 1971 Tire Pressure
Hello, what tire pressure do you like for a 1971? 24 lbs seems low. Thank you
Old Mar 18, 2022 | 11:21 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I think it depends on what tire type you are running. Modern radials are generally 30-34psi. If you are using repro bias-ply they had lower pressures like 24 psi.
It's a trade-off no matter what: higher pressure gives higher gas mileage but harsher ride; lower pressure is opposite. You will wear the tires more on the outside edges with low pressure and in the center with higher pressures.
Old Mar 18, 2022 | 11:46 PM
jbakyy's Avatar
jbakyy
Bf Goodrich radial ta, thanks
Old Mar 19, 2022 | 07:02 AM
pltmgr's Avatar
pltmgr
I run 30 psi in mine
Old Mar 19, 2022 | 03:18 PM
jbakyy's Avatar
jbakyy
Thank you
Old Mar 19, 2022 | 05:43 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
And I run 32psi. have for many years with excellent tire wear.
Old Mar 19, 2022 | 05:58 PM
barkingrats
I should have said, "You will wear the tires more on the outside edges with under inflation and in the center with over inflation."
Running a radial at 24 psi will likely show more rapid outside tread wear whereas 40 psi will likely show rapid center tread wear.
Proper pressure depends on the tire design and pressures recommended by the manufacturer. My Tacoma runs at 40-44 psi from the dealership service and tire sidewall - but that's a completely different design and intended service. My Corvette radials sit right around 30 psi.
Old Mar 20, 2022 | 10:00 AM
jbakyy's Avatar
jbakyy
Thank you
Old Mar 20, 2022 | 11:26 AM
Roger Dodger's Avatar
Roger Dodger
BFG Radial T/A
30psi.
To 1971 Tire Pressure
