Throwout bearing or fork pivot?
Old Mar 22, 2022 | 03:44 PM
2016 Z's Avatar
2016 Z
Default Throwout bearing or fork pivot?
So my 75 has developed a chirp when the clutch is engaged and the car is in neutral (or when driving). It stops with slight pressure on the pedal and there is no whirring or grinding. I lubed the linkage but while doing so realized the chirp is inside the bellhousing. Its clear as day when shaking the fork - see video - Is this the pivot or could this be the bearing wallowed out and squeaking? Or is there no way to know? Just trying to decide if I can hold off on pulling the trans or if I need to stop driving now and get to work....
Thanks!
Old Mar 22, 2022 | 07:59 PM
LT-1 kid's Avatar
LT-1 kid
sounds like the pivot ball on the bell house
Old Mar 22, 2022 | 11:08 PM
forman's Avatar
forman
spray a little wd-40 on there
Old Mar 23, 2022 | 07:45 AM
Mr D.'s Avatar
Mr D.
The chirp is a squeak, and the squeak is due to metal-on-metal contact. As Forman said WD-40 or dab of grease should quite that down.
Old Mar 23, 2022 | 07:59 AM
stingr69's Avatar
stingr69
if you only hear it when the clutch pedal is in motion moving up or down, it is probably the pivot. You might be able to shoot some lithium grease in behind the fork to lube the ball stud.
A bad throwout bearing would continue to make noise any time the pedal was loaded. There are other problems that make that sound so not 100% conclusive there.
Old Mar 23, 2022 | 08:15 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I think it is dry along the shaft......lube not only the ball, but the throwout slide....
Stick a whip from a grease gun in there...give it a couple of shots and rub it in with a long painters brush.....I like Royal Purple grease.
Jebby
Old Mar 23, 2022 | 09:13 AM
2016 Z's Avatar
2016 Z
Jebby
I think you're correct. I lubed the pivot and the sound remains so I'll try your suggestion before I pull the trans. Thanks!
To Throwout bearing or fork pivot?
