1978 - Radiator Drain Plug Leaking
Old Mar 23, 2022 | 01:00 PM
downingracing's Avatar
downingracing
Default 1978 - Radiator Drain Plug Leaking
I've been searching and it seems like the drain plug on the radiator can be an issue. With the car sitting for 2 weeks on the lift, this morning I noticed that the drain plug area is leaking. (on the lift waiting for new power steering lines to arrive)This new leak started sometime between last night and today. The car has not been started or touched, but this is now an issue I need to address. I'm looking for first-hand experience with the radiator drain plug and leaking. Any advice on what to do or not do would be greatly appreciated. I'd like to not replace the radiator if I can get away with just fixing or replacing the drain plug. Comments from my search make touching the drain plug seem like a very bad idea. Thanks!
Old Mar 23, 2022 | 01:56 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
You can replace the pet **** if that is what's leaking. Pretty easy fix.
Old Mar 23, 2022 | 06:43 PM
HeadsU.P.'s Avatar
HeadsU.P.
Another option is a Sacrificial Anode Rod drain plug. Much like your home hot water heater has, but smaller scale.
If you have any aluminum engine parts, heads, water pump, block, or Rad, etc there is always corrosion present with those metals.
The Anode rod will take the blunt of the chemical reaction.
Summit sells the Anode drain plug.
Old Mar 27, 2022 | 07:31 AM
downingracing
Thanks for the replies! The car has a plastic drain plug for the radiator installed with a rubber seal. I played around with it and can get it to only "drip a few drops" a day vs. a puddle under the car, but this seems like it could/will be an issue when the system is under pressure. I haven't had time to really mess with it. It's been pretty cold here in Ohio so as soon as the weather gets back to at least the 50's, I'll get back at it. I'm trying to identify the right drain plug to purchase from Summit, but that is proving to be harder than I thought it would be.
Old Mar 27, 2022 | 07:41 AM
bmotojoe's Avatar
bmotojoe
It's most likely is either a 1/8" NPT or a 3/8" NPT either can be found at your local auto parts house...
Whatever you replace it with try finding one made of Brass.
About $3.00 no shipping...
Old Mar 27, 2022 | 09:25 AM
HeadsU.P.'s Avatar
HeadsU.P.
Summit Racing
Fluidyne
FHP 32004 $24
If its too long to fit up into the rad, I would think you could shorten it with a hacksaw, easily.
Old Mar 27, 2022 | 10:09 AM
derekderek's Avatar
derekderek
the fact that it is plastic makes me less worried. fighting a metal plug out of a 40+ year old copper radiator could get messy. also, it may be the wrong thread plastic plug somebody forced in there. fortunately copper trumps plastic.
Old Apr 16, 2022 | 04:31 PM
downingracing
Originally Posted by HeadsU.P.
Summit Racing
Fluidyne
FHP 32004 $24
Thanks for the link! I got the part and replaced the plastic drain plug that someone forced in there with an O-Ring seal on it (that leaked like it wasn't even there!). Seems to have corrected that issue!
Also replaced the P/S high pressure line from the pump to the rack. That leak is also now fixed. I'm moving the car off the lift tomorrow and think it's ready for my first drive! (other than the short trip home when I bought it)
Super excited to get it on the road with the T-Tops off!
Old Apr 16, 2022 | 06:21 PM
HeadsU.P.'s Avatar
HeadsU.P.
When I bought my car, it had a NPT bolt in the bottom of the radiator for a drain plug.
Its still there. I love it. However, I have the Fluidyne Anode Rod ready to go for the next project that requires draining the Rad.
Never been a big fan of "Petcocks". They open when they shouldn't or won't close when they should. Or the little handle snaps off.
Old Apr 21, 2022 | 01:29 PM
downingracing
To close this out: THANKS for the help! I was able to replace the plastic drain plug someone had forced into the radiator (using an O-ring) and replace it with a 1/4 NPT fitting. I ordered two things to try:
https://smile.amazon.com/dp/B07NVPR4...t_details&th=1
and
https://smile.amazon.com/dp/B0876LSX...roduct_details
I ended up cutting down the Zinc Anode piece to make sure it would fit into the radiator. Worked great. I ordered both because I wanted to make sure I could make one of them work since the car was already on the lift. Tightened right up and no more leak. I was able to take my first cruise in the car this past weekend. Just a few miles around the local back roads. Going to drive it to work tomorrow (weather depending) and that will be a 17 mile trip (one way). Car seems to do great and is a blast to drive. Thanks again for the help!
To 1978 - Radiator Drain Plug Leaking
