Steering box bolt redesign
Old Mar 27, 2022 | 10:00 PM
anesthes's Avatar
anesthes
Default Steering box bolt redesign
I know the NCRS guys would flip out on this, but have any of you considered tapping your steering box to use bolts with hex heads (or welding nuts/thread inserts) on the steering box so it can be mounted like every other steering box on the planet?
I have my box out right now, installing a brand new unit, and these three cruddy carriage bolts from 1968 look to belong in the trash. Pretty much every other GM box from 1963 to the 80s ran a 7/16-14 bolt and the box was threaded.
I have side pipe headers, and getting the back nut off was a pain to swap the box. Otherwise swapping the box is like a 20 minute job.
Aside from "judging" I can't think of a reason not to.
Old Mar 27, 2022 | 10:12 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Other than the tire will hit the bolt head on full lock with a standard bolt head. There is a reason they used the carriage head bolts. . . . . tire clearance.
Old Mar 27, 2022 | 10:27 PM
anesthes's Avatar
anesthes
Hah really?
This must have been an "oh crap" design change.. The tire hit the bolt heads, so they decided to step down to a 3/8 carriage bolt.
-- Joe
Old Mar 28, 2022 | 02:07 AM
Bikespace's Avatar
Bikespace
Originally Posted by anesthes
Hah really?
-- Joe
Yes, really. I have standard bolts, and the extra stiffening plate, with the Borgeson box conversion in my 79. The tire absolutely rubs on these bolts. There is an adjustment that can limit the steering angle and prevent this, but the carriage bolts were certainly GM's fix for this issue.
Old Mar 28, 2022 | 08:45 AM
anesthes's Avatar
anesthes
What size tire are you running?
I wonder if running button head torx bolts would be a good solution.
-- Joe
Old Mar 28, 2022 | 09:14 AM
Bikespace's Avatar
Bikespace
IIRC, they are 5/16" bolts, so 1/2" hex head? I forget. They came with this kit:
https://www.speedwaymotors.com/RideT...te,461306.html
The button heads are a good idea, if they come in grade 5 or 8.
Old Mar 28, 2022 | 09:44 AM
anesthes's Avatar
anesthes
Hah you are right, these are 5/16. .
I think I'm going to weld some nuts to the box and run button head bolts.
To Steering box bolt redesign
