Why does the idle continue to lower even after initial warmup?
Old Mar 31, 2022 | 10:41 PM
brassplyer's Avatar
brassplyer
Default Why does the idle continue to lower even after initial warmup?
Trying to understand some carb theory. I just installed a Holley Brawler carb - basically a clone of a double-pumper. I notice that with this carb as well as the Street Avenger it's replacing once it's warmed up to where the choke plate is full vertical and the fast idle cam is no longer in play, the idle will continue to lower a bit after driving around. Say go from an initial 900-ish RPM to 700-ish.
Why does that happen?
Old Mar 31, 2022 | 11:00 PM
Bikespace's Avatar
Bikespace
If that carb has a high-idle similar to a Q-Jet, it is either on, or off.
Continued idle lowering may be due to something else warming up. TVS causing (or more likely eliminating) a vacuum leak, perhaps? Carb gasket only sealing when warm?
Old Mar 31, 2022 | 11:03 PM
brassplyer's Avatar
brassplyer
TVS is...?
Old Mar 31, 2022 | 11:18 PM
Bikespace's Avatar
Bikespace
Thermo-Vacuum Switch. They can either open or close depending on temperature.
Usually these are in your water neck, and do things like shut your heat riser, enable EGR, etc.
I'd look for a vacuum leak, or change. Is the vacuum advance connected to a manifold vacuum port, with nothing else T-ed into it?
Post some photos!
Old Apr 1, 2022 | 02:10 AM
brassplyer's Avatar
brassplyer
Post some photos!
Right now it's raining with no immediate signs of letting up but the vacuum advance is connected to a nipple coming off the primary metering block. That's how it was set up on the other carb when I got it.
Old Apr 1, 2022 | 07:15 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Disconnect the vacuum advance......it should not be above the blower anyway and certainly not on the ported vacuum nipple. If you think you have to have it.....it should be below the blower like your boost reference power valve.
I have never built or tuned any blower setup with vacuum advance....set a tight curve that pulls like 10-12 degrees and that's it. If it responds better with it hooked up...so be it.....but it has to be below the blower.
Jebby
Old Apr 1, 2022 | 09:53 PM
brassplyer's Avatar
brassplyer
Jebby
Thanks! I disconnected it (yes, I put a cap on the metering block nipple) so far don't notice any deleterious impact.
Maybe you could chime in on my recent carb/ignition tuning thread.
Old Apr 1, 2022 | 10:05 PM
Bikespace's Avatar
Bikespace
I'm glad @Jebbysan is paying attention. I'd forgotten about your blower.
To Why does the idle continue to lower even after initial warmup?
