Measuring for quench...
Old Apr 7, 2022 | 09:17 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by scottyp99
You bolt the head down and remove it. I guess if you have a money tree out in the back yard you can afford to ruin a brand new head gasket just to avoid doing some easy, simple math . I don't have a money tree, so I guess I'll just have to add the compressed thickness of the head gasket to the measured thickness of the clay.
Scotty
I keep an old SBC and BBC head gasket on the wall….for this reason….
If the engine was rebuilt before….use the old head gasket when you tear it down….
It is a laugh….can’t tell you how many people ask me why I have old head gaskets on the wall….
I have used shim stock or old feeler gauge tongues as well….
Jebby
Old Apr 7, 2022 | 10:26 AM
Corvette-ZL1's Avatar
Corvette-ZL1
your eagle rotating assy uses Keith Black pistons. several different KB 383 pistons say 1.433 compression height. plus half of 3.75 stroke plus 5.7 rod comes out to 9.008. they say the stock deck height of a small block is 9.025. your shop said they usually deck .005 to .010. it could have been decked twice. it could have been decked 15 or 20. i prefer if the shop knew and wrote down how much they took off. but if yours was decked .005 you are in the hole around .012 if decked 10 you are at .007 in the hole. so i realyl doubt you have the room to cut the block any farther. zero decks are for racing. a .028 composition head gasket will put you at .035 or .040 assuming your block is 9.015-20. not a horrible place to be for a quench height. aluminum heads? cuz i recall you talking 10.5 or so CR.
That's right. Aluminum heads (Edelbrock 5089 E-Streets). Thanks for this info!
Old Apr 7, 2022 | 03:51 PM
derekderek's Avatar
derekderek
but it is only a swag based on specs and info in posts. it pretty much points out the need to be sure. odds are about 100% that if builder hands you the assembled short block it will not have to come back apart, at least not for piston to head clearance issues. but hope for the best and plan for the worst...
Old Apr 7, 2022 | 05:09 PM
Corvette-ZL1
understood. Thanks again, derek!
Old Apr 9, 2022 | 01:08 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
It's a great idea, but if the clay is too thin, good luck getting an accurate measurement. Maybe there's a better material to use than modeling clay?
Scotty
I've done it that way for years....been using the same lumps of clay over and over on many engines.
I do it without the gasket and just add in the compressed gasket thickness. I've also used old gaskets.
My 555" has the pistons .009" OUT of the hole. When I ran it N/A for many years I had .028" total deck including head gasket. Yes...the pistons "kissed" the heads a little...never had an issue and bearings etc always looked brand new on teardowns when I would be changing up the combo. I'm using thicker MLS gaskets with the current twin-turbo combo and now have .032" total clearance. And it spins 8000 RPM crossing the line in the 1/4 mile.
JIM
