Dash Light Issue
Old Apr 13, 2022 | 08:35 PM
PM427's Avatar
PM427
Default Dash Light Issue
I have been reading and reading about this common issue and I am stuck. My instrument panel lights spedo and tach as well as my gauges quit working.
1st thought headlight switch.
Replaced that, the lights worked for a second and quit.
Fuses are good. Cant get the lights to come back on.
All other lights work just fine.
Where do I go from here?
ohh checked the ground on the speedo and tach it is connected.
Any help would be appreciated. I am stumped!!
thanks all
Old Apr 13, 2022 | 09:22 PM
Bikespace's Avatar
Bikespace
Are you sure your fuses are good, and conducting? I've had issues due to corrosion on fuses. Take them out and clean them, and measure for voltage, not just continuity.
What year car, BTW?
Old Apr 14, 2022 | 12:44 AM
carriljc's Avatar
carriljc
This may sound silly, but have you tried turning the ****? I'm guessing it's an early C3 with the lightswitch that dims the dash lights.
Old Apr 14, 2022 | 01:42 AM
Bluegoose95401's Avatar
Bluegoose95401
Some times the light switch itself goes bad. I have had that happen a few times. I’m pretty sure that’s what is wrong with mine. The parts for the light dimmer will get a break in them and the headlights will work but the gauges won’t.
Old Apr 14, 2022 | 01:21 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
See if there is power at the instrument lamp fuse when the headlight switch is pulled out. It gets its power from the light switch.
Old Apr 14, 2022 | 07:23 PM
PM427's Avatar
PM427
Thank you everyone
removed all fuses, cleaned the contacts, put new fuses in and back in business.
Appreciate all the help !!!!
Thank you
Old Apr 14, 2022 | 07:24 PM
PM427's Avatar
PM427
Thank you everyone
Thank you
Old Apr 15, 2022 | 09:53 AM
Charles Lee's Avatar
Charles Lee
thanks all
I have been going through mine with a wire brush and scraping any rust I can find, especially on Grounds. I was able to fix my fuel sending unit this way
To Dash Light Issue
