Stock Speaker Wires 71`
Old Apr 16, 2022 | 04:34 PM
farmerdick's Avatar
farmerdick
Default Stock Speaker Wires 71`
I just started the installation process(what a treat this is!!!) of a Custom Auto Sound Radio in my 71`. They have their color code for the different speaker locations. Their is a pair of wires for each speaker labeled L+ and L- example. The stock wires are lime green and black. So
my question is am assuming the black is ground? So i would connect their neg wire to the black stock wire. I know i can call them on Monday and they may or may not know the color code for the corvette speaker wires. So i thought i would throw this question out in the
mean time for any thoughts.
Thank you as always for any feed back.
Old Apr 16, 2022 | 04:47 PM
Mr D.'s Avatar
Mr D.
Post a picture of the Custom Auto Sound Radio wiring diagram.
Old Apr 16, 2022 | 04:58 PM
farmerdick's Avatar
farmerdick
I am sorry to say that I have not taken the time to learn how to download onto the forum. Basically there are 8 wires(wt and wt with blk stripe, grey and grey with blk stripe, purple and purple with blk stripe, green and green with blk stripe which go into a
common male connector and is plugged into back of radio. the leads with the black stripes have a label with the negative symbol on it. The ends of the leads have male ends. Hope this helps.
Old Apr 16, 2022 | 06:21 PM
Fly skids up!'s Avatar
Fly skids up!
To determine speaker polarity use a 9 volt battery. When positive and negative is apply correctly will move the speaker cone outwards.
Old Apr 17, 2022 | 05:06 AM
farmerdick's Avatar
farmerdick
Thank you. I will do that.
Old Apr 17, 2022 | 06:22 AM
Mr D.'s Avatar
Mr D.
Going off the OEM speaker wires being lime green and black the black would be the speaker neg (-) input and the green would be the Pos (+) input.
Your radio plug is as follows:
Left Front
White +
White/Black -
Right Front
Gray +
Gray Black -
Left Rear
Green +
Green/Black -
Right Rear
Purple +
Purple/Black -
To Stock Speaker Wires 71`
