please, need help
Old Dec 31, 2002 | 08:52 PM
vettedreams's Avatar
vettedreams
Default please, need help
Could really use some help on removal of transmission shifter removal from mounting bracket, thanks.
Old Dec 31, 2002 | 09:15 PM
wombvette's Avatar
wombvette
Default Re: please, need help (vettedreams)
4 Spd? Remove the bracket and the shifter at the same time.
Old Dec 31, 2002 | 09:41 PM
vettedreams
Default Re: please, need help (wombvette)
Yes, M-20 4 spd. the problem is the third bolt is covered and I cann"t seem to find a way to remove it, there are three bolts? am I right?
Old Dec 31, 2002 | 10:17 PM
BeachinVette's Avatar
BeachinVette
I have a M-20 bolted to my engine stand but I am at work I will not be home till around 10:30 est tomorrow,,, but I am thinking there is only 2 bolts mounting the bracket to the trans. and 3 mounting the bracket to the crossmember. I will check when I get home and post again if nobody gives you a firm answer.
Bob
Old Jan 1, 2003 | 03:58 PM
vettedreams
Default Re: please, need help (76 Red)
Thanks guys, got it out :D
To please, need help
