Help with headlight housing removal
Old Jan 1, 2003 | 11:29 AM
Terrys69coupe's Avatar
Terrys69coupe
Default Help with headlight housing removal
Starting winter project #1 rebuilding my headlight assemblies was wondering how to remove as much in 1 piece as possible .If it makes a difference its a 68.Thanks terry
Old Jan 1, 2003 | 01:03 PM
wombvette's Avatar
wombvette
Default Re: Help with headlight housing removal (Terrys69coupe)
It is possible to remove the whole thing as a unit. You will need to have all grille pcs. etc. removed to get it out.
Old Jan 1, 2003 | 01:15 PM
GTR1999's Avatar
GTR1999
I removed the assemblies from my 69 but I had everything out of the way first. I do mean everything- hood, engine, grills, horns,etc. Take your time it's a tight fit.
Good luck,
Gary
Old Jan 1, 2003 | 08:09 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I was able to R & R on my 75 in one piece but the bumper hardware all had to be removed, also the lower valence panel, air dam, etc. This was not a big deal for my project as I'm still re-assembling following a frame off restoration. :cheers:
Old Jan 1, 2003 | 08:26 PM
Terrys69coupe
Default Re: Help with headlight housing removal (Big Fish)
Thanks for all the sugestions since I'm also in the middle of a frameoff and cutting my front valance off .That will probably do the trick.Do new lower valance panels come with the holes predrilled for the chrome L shaped guards?Thanks Terry
To Help with headlight housing removal
