Gymkhana suspension
Old Apr 25, 2022 | 08:54 AM
TL79C3's Avatar
TL79C3
Banned Scam/Spammer
Default Gymkhana suspension
Hello Vet Heads
​​​​​​ OK so I've had my Vett for a couple years now. And I've discovered it has the Gymkhana Suspension. Based on research I am aware it is a stuff suspension. Other than that, what are the pros and cons. From what I have gathered it has a HD front springs and Shocks, 7 leaf rear spring and 7/16 stabilizer. However i counted 9 leaf, unles the upper and lower plate are not leafs. Ant thought and inputs will be greatly appreciated
Cruise safe
Old Apr 25, 2022 | 09:13 AM
Bikespace's Avatar
Bikespace
Congratulations! That is a very desirable option.
I'm surprised I beat @interpon to a reply on this. He detailed the rebuild of his Gymkhana 79 here, including the spring leaf count:
https://www.corvetteforum.com/forums...questions.html
When searching for other posts, it may help to also look for the original option code: FE7.
Old Apr 25, 2022 | 09:28 AM
panther-19's Avatar
panther-19
Veteran: Marine Corps
Another part difference with FE7 suspension is Aluminum rear struts. These are much lighter than the steel ones found on NON-FE7 option cars. Although they still use the multi leaf steel spring instead of the single leaf composite. Go figure.
Old Apr 25, 2022 | 09:56 AM
JiminSTLouis's Avatar
JiminSTLouis
My 1980 has the Gymkhana suspension. I haven’t had the opportunity to get under and explore it yet. It’s funny… the suspension option back then was $55.00 but the 8-Track stereo was $155.00.
Ps.
In 1980, 24.4% of Corvettes produced had the Gymkhana suspension.
Old Apr 25, 2022 | 02:11 PM
interpon's Avatar
interpon
I was not aware of this!!!!
aluminum strut rods?? great now i have to find those.. I have NEVER seen those available anywhere..!!!
@Bikespace i learned from you!
FYI here is your steel gymkhana replacement available today. original was 6 leaf steel.
https://www.corvetteforum.com/forums...af-spring.html
OP how about some pics?? are you sure not a 10 leaf replacement?
Old Apr 25, 2022 | 06:16 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
No factory aluminium struts on my '76. What years had these? I do have aftermarket aluminium adjustable strut rods now.
Old Apr 25, 2022 | 06:18 PM
Bikespace's Avatar
Bikespace
I'm thinking 82, and possibly 81.
Certainly the heim-jointed aluminum adjustables are better in every way, and a great upgrade for any car.
Old Apr 25, 2022 | 06:21 PM
Mrvettenick's Avatar
Mrvettenick
My car came with the FE7, and it has iron struts. What years are you talking about?
Old Apr 25, 2022 | 06:59 PM
panther-19's Avatar
panther-19
My 1982 CE with FE 7 had aluminum struts factory stock. I figured that was on every FE7 equipped car.
Old Apr 25, 2022 | 07:16 PM
Mrvettenick
Maybe for '82. Interesting.
Old Apr 25, 2022 | 11:24 PM
Bikespace's Avatar
Bikespace
I'm still not sure of the application of the aluminum strut rods. Perhaps (late) 82 only? The GM part number is 14041095, and several examples are up on eBay right now. Perhaps someone with a Corvette/GM part book handy can confirm the application, but I don't know if they they are specific to FE7, or just to (late production) 82s.
Deja Vu, I had a similar conversation 2 years ago:
https://www.corvetteforum.com/forums...an-81-a-2.html
Old Apr 26, 2022 | 08:02 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
My 77 came with gymkhana suspension. It had Bilstien shocks. 7/16ths rear sway bar , I believe 1 1/8 front bar.
As stated, different springs from standard, But, no alloy strut rods.
Now all that's left of the original gymkhana suspension is the front springs that I cut a coil off and the front sway bar.
But the links and bushings have been replaced. Original Bilstiens lasted about 30 years. Now it has more modern Bilstiens on it. and thicker rear bar and VB&P mono spring.
The gymkhana suspension was a good value in the day. but 45 years on. most of it should have been replaced by now anyway.
Old Apr 26, 2022 | 09:33 AM
fake's Avatar
fake
I bought my 77 because it handled like a go cart with the FE7 suspension.! Nothing like it compared to a base car.. My struts are steel.
To Gymkhana suspension
