1981 Corvette AC Vacuum Hoses (Interior)
My main problems are these; finding the rubber fittings that go onto the end of the vacuum hose like the factory originals (I’m assuming it’s original and I can always buy regular vacuum line and color code if necessary.)
Finding the red vacuum line (I can’t find it anywhere in the dash; is it even supposed to be there?)
I will attach photos and the diagram I am using for reference, any guidance would be very appreciated.
This is the end of the line that connects to the vacuum diaphragm on the drivers side. Note the rubber fitting on the right line that I am referring to; where can I find these rubber pieces?
This is the other rubber piece that attaches to the AC switch, again the mouse chewed this up completely. Do new switches come with this or do I even need it?
These are the ends that were supposed to be connected to the AC switch, but the darn mouse chewed them up.
These are all the vacuum lines that I could find in the dash that were not connected to the AC switch. But no red vacuum line. (Side note, the wiring is a mess but I did clean it up some.)
This is the diagram I am using as reference to the vacuum line location; I cannot find the red vacuum line anywhere. Do I even need it?
77-82 AC Control Panel Vacuum Hose Kit
Be The First To Review This Product
Item #:
ZAH-304
$32.99IN STOCK - Ships Tomorrow
Qty-
Add to Cart
ADD TO WISH LIST
Skip to the end of the images gallery
The hardest part will be feeding the new hose ends through the firewall grommets.
The new rubber hose is a larger ID size then original so the grommet holes will need some reaming to get them through.
I also noticed on your diagram the port numbering of the vacuum switch is labeled a little different than a Corvette, your diagram shows #2 as OFF, there is no off.
This switch was used on both A/C and Non A/C cars so follow the porting on the left.
If you still have the Delco or a ACdelco dealer replacement switch the ports should be numbered.
Updated Vacuum Switch Port Circuits
See where it is circled in red on the drawing above?
#1 also tees off to the vacuum switch that operates the hot water shutoff valve on top of your heater box inside the cabin.
The others,
One will go to the plenum actuator (green hose)
The other will go to the Hot Water shutoff valve in the one heater hose (white hose).
If it were me I would run a dedicated line from the manifold fitting through the filter and up next on the firewall your HVAC line now tees in.
You will need to purchase the correct reducer to make the connection.
For the reducer, a short length of 1/8" ID vacuum hose will fit nice and sung over the existing vacuum line entering the cabin.
I believe the vacuum line from the manifold/filter is 1/4"...
You can cap things off if you like but loose ends sometimes turn into problems down the road.
Easy peasy ...
Easy peasy ...
After hooking up all the vacuum hoses I believe I got it working properly again for the most part. The main blend door on the passenger side towards the fire wall opens and closes; blows nice and cold, the defrost flap opens perfect. The foot door on the passenger side is stuck shut; no big deal I guess. The only thing I’ve noticed is when I turn the AC on the two ports on the switch they I did not use makes a loud hissing. Should I cap it? Or should it sound like that. Thanks for all the help.
What about the door out in the cowl area, tucked down inside the fender well area? You can see it if you look down in there by the end of the blower swirl cage area.
The only unused port would be #2 exhaust port, and its only porpoises is to exhaust otherwise trapped energy from a none venting actuator.
Once an actuator(s) have exhausted there should be no more sound unless the switch itself is faulty.
The foot door (or air re-circulation door) is held shut with that heavy spring, so it is possible it may be frozen shut or your just not pushing hard enough against the spring resistance.
That circuit is also connected to the plenum actuator in the engine compartment. Follow the green hose in the wiper gutter.
If you remove the plastic trash screen you will see the plenum door and the actuator is on the inside, you have to remove the door held in by screws.
If the hose nibblers did what they did on the inside of the car,,, well you might want to check that hose too. If so there will not be enough or no vacuum to open either door...
See, mine was crushed during cars assembly and never worked, I think another forum member found the same thing...
Plenum actuator Short Hose...
Last edited by bmotojoe; May 12, 2022 at 08:00 PM. Reason: Added Air re-circulation door
