Looking for a 75 convertible latch spring
Old May 1, 2022 | 06:36 PM
Z51JEFF's Avatar
Z51JEFF
Default Looking for a 75 convertible latch spring
Is it possible to buy just this spring? This is for the rear latch pin on the rear deck,driver side for the convertible for a 75.
Old May 1, 2022 | 08:13 PM
'73and'75's Avatar
'73and'75
Jeff, something is missing from your latch. The lever that the rod with the pigtail attaches to is missing (unless you removed it). The lever is held in place with the hex bolt. As far as I know the spring is not available separately.
Old May 1, 2022 | 08:56 PM
Z51JEFF's Avatar
Z51JEFF
Hey Guy,I'm in the process of getting it apart.
Old May 2, 2022 | 09:34 AM
speedreed8's Avatar
speedreed8
You may check out McMaster Carr industrial supply. They have hundreds of springs. Just need to measure what you have and compare.
GM probably didn’t use anything special.
Old May 2, 2022 | 10:32 AM
'73and'75's Avatar
'73and'75
Jeff, when I look at how the latch mechanism is constructed, I do not see a way to remove and reinstall the spring.
LH part # 3942775 RH part # 3942776
You may have to buy a repop until you can locate an NOS piece.
https://www.corvettecentral.com/c3-6...e%2fdecklid%2f
Old May 2, 2022 | 10:53 AM
Z51JEFF's Avatar
Z51JEFF
I've ordered an aftermarket part for the time being until I can find an NOS part. Thank you for the part numbers,greatly appreciated!
Old May 2, 2022 | 11:12 AM
'73and'75's Avatar
'73and'75
Or buy a nice used one instead of the repop to hold you over until you locate an NOS piece.
https://www.ebay.com/itm/29441516903...YAAOSwx1phTOd0
Old May 11, 2022 | 08:09 PM
Z51JEFF's Avatar
Z51JEFF
Guy this is the part I'm looking for,it's on the DRIVER door,part of the lock mechanism. I'm looking for the part number.
To Looking for a 75 convertible latch spring
