I put in my refreshed SBC and it drove nice just breaking it in town and highway and I parked it in my garage. Hundreds of nice shifts on two separate days. Now the clutch won't disengage even at max adjustment with your pedal on the floor. Arm moves back and forth and is still clipped on the pivot ball.
This motor and tranny was together before. So no parts changed.
I took apart the linkage today and it might that I don't have enough movement forward. It's a high end 1000 plus HP clutch... The clutch disk still had writing on both faces from years of abuse. My new motor is a 672 hp 434 Motown with a 22 pound SFI 168 tooth flywheel. I'm going to extend the throw and see if it works
The problem is with your clutch pedal on the floor and maximum adjustment it doesn't release the clutch completely. so when you shift into gear the tires start rotating. It's up off the floor
Mine was similar. I ground on the pedal bracket a bit and took out the floormat on the drivers side and all is well. Just needed maybe 1/4" more throw.
Now, just wish I could get my Terminator happy, then I would be happy....
It went from working fine for years and I reinstalled my spare 434 ci SBC which used the same flywheel, clutch , and PP previously. I have been driving the new motor gently just breaking it in with 100's of smooth shifts and I parked and now these problems.
I have friend bringing a bore scope to see if we can figure out why the PP is NOT disengaging.
I talked to ACT tech support and this fits our TKO 26 spline 5 speeds. Good for up to 700+ foot pounds of TQ and 1000+ hp. I can't figure out why mine is not releasing so it's tranny pull time.
FWIW I had a '66 with the same symptoms. Turned out the pedal itself was failing. I don't remember what part of the pedal cracked and bent, but over a period of a couple of weeks I lost most of my pedal travel. Solution was to buy a reproduction pedal.
