Wheel studs won't come out...
Old May 8, 2022 | 09:40 PM
Mpls Funk's Avatar
Mpls Funk
Default Wheel studs won't come out...
Hi all, Looking for suggestions/advice. I am trying to change my wheel studs on rear passenger wheel. I already did the drivers side. Two of the studs came out relatively easy, but three are really fighting me. I have tried using an air hammer/chisel (not to cut, but to "pound" on the end of the stud with high impact rates). That worked well for the other studs, but isn't working on these three. I tried a larger hammer...that doesn't work. I also tried putting some heat to the flange and then the larger hammer and that isn't working. I'm a little nervous about putting a lot of heat to it...and I'm a little nervous about banging it hard with the larger hammer as I don't want to do damage to wheel bearing, etc.
From my perspective, the only remaining option is drilling? But my concern there is that I'm not good at finding center to start with...so then, as I progressively go to larger size bits, I'm concerned I might start taking material off the flange (assuming I'm not centered)....and if I do that, will I have issues getting a new stud to seat and hold properly?
Any thoughts/suggestions would be greatly appreciated!!
Old May 9, 2022 | 07:00 AM
cottoneg's Avatar
cottoneg
You may want to consider removing the entire arm and do an upgrade.
You could have the machines push out the old studs and install new ones. You could also install new bearing and make your parking brake from Stainless steel components.
Old May 9, 2022 | 07:35 AM
lionelhutz's Avatar
lionelhutz
Did you actually give them a good smack with a 3-5lb sledge or were you being gentle with them giving them little love taps? If you haven't yet, give them a decent whack and see what happens.
The bearing can take a lot. To replace rotors that were rear bolted to integrated hubs on my truck I took them out of the uprights by beating on the rotor using a 5lb sledge. About 70k miles later I thought one bearing was bad and replaced it, even though it actually wasn't making the noise I thought it was. The other bearing is still going 100k miles later. The factory doesn't bother with anything to protect the bearing to upright joint from rust and they get really stuck in there.
Old May 9, 2022 | 07:53 AM
Mpls Funk's Avatar
Mpls Funk
I generally agree with you. However, I called a shop in the metro and he basically said they wouldn't get it done for at least 2 months and likely longer. The driving season in MN is too short. So I want to get this done and drive this summer and then have someone rebuild both arms over the winter.
Old May 9, 2022 | 07:55 AM
Mpls Funk's Avatar
Mpls Funk
I probably have not hit them as hard as you suggest... It really scares me!
Old May 9, 2022 | 02:02 PM
69L88's Avatar
69L88
In your previous post “Another stuck rotor thread - help” you engaged in a discourse on how to remove the rivets and eventually were successful in getting them out after drilling them. The wheel studs are harder than those rivets but the process outlined in that thread is pretty much the same for the studs. Be sure to have high quality cobalt bits and take your time.
Another option is to trundle down to O’Reilly Autoparts and see if they have any specialized tools to press the stud out with. I’ve seen some YouTube videos where a tie rod removal tool was successfully employed.
Old May 10, 2022 | 06:10 AM
cottoneg's Avatar
cottoneg
When the studs come out, especially after hitting them with a hammer, check your run-out.
To Wheel studs won't come out...
