50cc accel pumps?
Old May 10, 2022 | 06:50 PM
brassplyer's Avatar
brassplyer
Default 50cc accel pumps?
Someone mentioned 50cc accel pumps as a performance upgrade. I don't know what the capacity of the stock pumps on my 850 cfm Holley Brawler are. I've got a Weiand 142 blower on a ZZ4 crate motor, it isn't slow getting going now - would I likely gain anything?
Thanks.
Old May 10, 2022 | 08:18 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
a little background...most stock are 30cc which is 3 cc and the upgrade is the 50cc which is 5cc. They are measured with 10 strokes, thats how you get that number.. Anyway the performance upgrade would be in a few waysbut only to eliminate bogs
without a nozzle change you will get a longer duration to your pump shot going from 3cc to 5cc. if you swap to a lot larger nozzle you would need the 5cc to maintain the duration with the larger volume. Then you can start messing with the cams to change ramp speeds for what your squirt would look like.
If you arent experiencing a bog you will not see a difference. The pump is to make up for the increase in air flow when you stab the throttle
Old May 10, 2022 | 08:36 PM
brassplyer's Avatar
brassplyer
a little background...most stock are 30cc which is 3 cc and the upgrade is the 50cc which is 5cc. They are measured with 10 strokes, thats how you get that number.. Anyway the performance upgrade would be in a few ways to eliminate bogs
Thanks - since posting I called Holley they say the stock pumps are 30cc.They seem to get the job done.
Old May 11, 2022 | 09:41 AM
gkull's Avatar
gkull
People on the forum that went the 142 route found it's limitations on boost even with bigger carbs and pulleys. The next step was using a NO2 spray plate under the carb.
Old May 11, 2022 | 01:04 PM
ctmccloskey's Avatar
ctmccloskey
I don't remember any engines that actually needed the 50cc accelerator pump diaphragms.
Even a Custom Built A.E.D. Holley used the standard 30cc pump diaphragms on a 850 Double Pumper for a thirsty high performance Big Block. This carburetor was tweaked to flow over 1100 cfm for my L88 replica.
Unless your engine really needs the extra fuel I would continue with the 30cc pump diaphragms. Squirting almost double the original 30cc's would certainly use a lot more fuel down the road.
Where are the 50cc pumps used? What kinds of applications actually need the extra fuel? Now I am curious....
Old May 11, 2022 | 02:01 PM
brassplyer's Avatar
brassplyer
Lol - yeah not with the stock ZZ4 hypereut pistons and powdered metal rods. I'm probably pushing my luck as it is - the presumed 75 - 100 hp bump is plenty. Can't imagine why I would ever need more power in a car that's not being taken to the track regularly.
The couple of brief stoplight "conferences" *cough* I've had weren't even close, last one was some guy (I assume - it was at night and their windows had dark tint) in a rumbly, dressed up C4. I never went any faster than about 50 and there was a lot of pavement between my back bumper and his front bumper - I didn't even get on it until I saw he was.
Old May 11, 2022 | 08:33 PM
Rescue Rogers
It works great for my tri power setup. With no outboard accelerator pumps I use the extra 2 ccs as I floor the accelerator, they dont run dry while the carbs tri to catch up. I have softer springs in the outboard vacuum pods so they come in faster, with the same squirters,
Old May 11, 2022 | 09:50 PM
brassplyer's Avatar
brassplyer
Hmmm - so really the only way to know if they're going to help is to get them and see what happens.
Old May 12, 2022 | 01:21 AM
brassplyer's Avatar
brassplyer
Should I need anything but the 50cc diaphragms? I see there are "conversion kits" - should the diaphragm just be a drop-in to my current setup?
Old May 12, 2022 | 06:15 AM
Rescue Rogers
Its a pump and the diaphragm.
Old May 12, 2022 | 06:21 AM
Harris Roc Malouda's Avatar
Harris Roc Malouda
For reference:
I got an AED 850 Annular Booster Holley.
It got a 30cc stage 1 and 50cc stage 2 pump.
Also it got the blue actuator cam.
It works flawlessly on my 670 hp engine.
Engine builder advised getting a 850 for that BBC so i did..
Old May 12, 2022 | 06:26 AM
Rescue Rogers
Unless you are experiencing a flat spot or bog when you accelerate specifically due to a lean spot when you stab the throttle, you wont gain anything. I would make sure your carbs are boost referenced to the manifold below the blower before playing with the accelerator pumps to ensure they are operating properly. This will ensure the power valve opens dumping about 10 jet sizes more fuel into the engine under heavy load with a steady throttle from each carb
Old May 12, 2022 | 08:14 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
What size squirters are you running on the carb? The 50cc pump is really used when using a squirter over a 38.
Old May 12, 2022 | 12:39 PM
brassplyer's Avatar
brassplyer
When I talked to Holley I believe he said 33 is standard and that the 30cc pump is supposed to be good up to 37.
Old May 12, 2022 | 12:51 PM
Rescue Rogers
if you increase the volume of the pump but dont increase the jet size the squirt lasts longer. As you move through the accelerate range the valve moves so much, but does not refill until you back off the accelerator to reload it. WIth a larger volume you may still have more shot in the chamber so you gain that much more extra fuel for an additional jab if you decide to go further in the throttle. Its not just about the jet size. If you increase the size of the jet, you need to increase the volume to compensate for the pressure drop. I've heard around a 38 jet or larger as well. I will have to look to see what my last squirter size was . I believe its 32-34
Old May 12, 2022 | 08:43 PM
HeadsU.P.'s Avatar
HeadsU.P.
The larger 50cc pump arm may not clear most Intakes.
So, a spacer will need to be added under the carb base for clearance.
Not a big deal on any other vehicle but with C3s hood clearance it is a . . . . . . . . .
Old May 13, 2022 | 12:35 AM
brassplyer's Avatar
brassplyer
The carb is sitting on a Weiand blower.
To 50cc accel pumps?
Old May 13, 2022 | 08:21 AM
HeadsU.P.'s Avatar
HeadsU.P.
Ok. But you still have a carb pad to mount the carb. Isn't that blower the same clearance as a Intake Manifold? IDK
Those bigger diaphragms have a slightly longer stroke to the pump arm.
Old May 13, 2022 | 09:28 AM
TCracingCA's Avatar
TCracingCA
We dialed in 50 pumps on two of our cars that push 8k redlines.
Old May 13, 2022 | 09:32 AM
Eric P's Avatar
Eric P
50cc is only an upgrade on a carb that didn't come factory with it if it's needed for some reason like way way too big of a plenum or to make up/hide a faulty carburetor circuit or bad metering block
