Temp AFR setup
Old May 17, 2022 | 07:31 PM
joserpaq's Avatar
joserpaq
Default Temp AFR setup
Hello
I’m looking to install temp AFR gauge to dial in carb and wanted to push o2 sensor up exhaust pipe versus using bing since it’s temporary.
Question how far in will it need to go and does anyone have recommendation on how to shield cable so they don’t melt?
Old May 17, 2022 | 09:20 PM
derekderek's Avatar
derekderek
use a heated sensor and it doesn't have to go in far. boat guys twist the o2 sensor on the end of a coat hanger and run it up about 2 feet. and you don't have to worry about water wrecking the sensor. and back couple feet of exhaust won't melt wires.
Old May 18, 2022 | 07:38 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
same subject different post. Jebby posted a link
Old May 18, 2022 | 07:41 AM
Rescue Rogers
here ya go. it mounts on the end of the pipe with the sniffer shoved into the pipe, sensor is vertical
https://www.jegs.com/i/Innovate+Moto...r%20Categories
amazon is cheaper
Amazon Amazon
Old May 18, 2022 | 08:15 AM
69ttop502's Avatar
69ttop502
I am using a Daytona sensors unit and this is there instructions on making a sniffer.
https://nebula.wsimg.com/42ed239ad81...&alloworigin=1
To Temp AFR setup
