Torque spec?
Old May 23, 2022 | 10:49 AM
kodpkd's Avatar
kodpkd
Default Torque spec?
I have a 79 differential cover. It has 7/16" center spring mounting bolts,,, not the earlier big 9/16" bolts. I know the torque spec is NOT 55 lbs to 75 lbs, but I am not sure what the spec is supposed to be on the 79. I do know they need to be tightened with full weight on the rear wheels.
Old May 23, 2022 | 01:16 PM
wwiiavfan's Avatar
wwiiavfan
If you can't find it, I'd go with 75, as that is the same as lug nut torque, and those are 7/16" as well.
Old May 23, 2022 | 01:23 PM
kodpkd's Avatar
kodpkd
I tried the higher end when I thought the range was 55 lbs to 75 lbs..... That number will bend the 4 hole spring plate.
Old May 23, 2022 | 07:32 PM
PJO's Avatar
PJO
Veteran: Marine Corps
Per the 1978 AIM 35 to 50 lbs feet with weight on wheels for the 4 spring mount bolts
Old May 23, 2022 | 07:38 PM
kodpkd's Avatar
kodpkd
Thank you. That is interesting, a 15 lb range.
I wish I knew why someone put a 78 diff cover on a 68,,,,, instead of a heavy duty one.
Old May 23, 2022 | 08:12 PM
PJO's Avatar
PJO
A friend had one, found one cheap or he had one lying around. Install 2 shims and your done no need to spend the big bucks.
Old May 23, 2022 | 08:23 PM
kodpkd's Avatar
kodpkd
Part of what I don't understand. I have a 2 1/4 inch wide spring, there isn't enough room on the sides to put in a shim, but is has 7/16" center bolts.
To Torque spec?
