small chambers are that heads only really positive feature. a point of compression gets you 4% power increase from 7 to 9. 3% 9 to 10 and less than that with higher CRs. if you own them and they are in good shape is one thing. if you are shopping for heads, look aftermarket.
Problem is, if he's shopping for heads specifically looking for a small chamber... there just aint much out there for little money. Last i checked (not long ago) it was pretty bleak. There were some Chinese Ebay specials that looked promising last year, but they've since disappeared. Everything is 64cc or bigger.
Think world or Dart offers iron 58cc heads,
Trick flow still sells their 305 head 58 also
Has to be others?
I should addend... when I was looking anyways, i needed aluminum. There were iron heads out there, but a cheap, decent, aluminum sub-60cc head never quite presented itself to me. I tried to find some old LT1 or LT4 heads too, not sure if that would work. Didn't find any anyways.
It might be good to know what the OP is trying to accomplish. Lots of heads out there. Small chambers, milled heads, piston swaps..... other ways to get it done if you know what needs to be done.
FYI….the Trick Flow DH175 head is a 60cc chamber…..
10:1 on a 327…..10.6:1 on a 350 roughly….given a flat top four eyebrow piston .010 in the hole with a .041 head gasket….
I still have a set of the cast iron Double Hump heads that came on a small block I bought three decades ago. They were used on a 1970 LT1 Block and the engine was running great with them. I remember the compression was around 11.1-1 or in that neighborhood. They were perfect for a good running small block back in the day. I guess the newer aluminum relegate them to the parts pile. Does anybody even use them any more?
Dart has iron 49cc chamber heads 180,200,215,230 cc take your pick. Valve angle ends up 21 degree. That can be changed with pistons from both mahle or probe. Or you can simply fly cut the valve notches in any 23 degree piston. Isky makes a fly cut valve to do the job or you can use old valves with either some emory or sandpaper glued to the valves.
only if keeping original is needed. Modern heads have far superior cumbustion chambers and 52 years of known advances on the ports learned over that time period already cast into them.
OP those trick flows I mentioned are aluminum. They have a 1.94 valve but still flow ok for what they are certainly better than GM double humps. If you take a head with a reasonably thick deck you can always mill them down from 64
Heck why not grab some trick flow alum double humps and have them milled for you? So you might have to have your intake cut some no big deal. Goal accomplished! The china double humps dont flow worth a chit barely as good as stock fwiw.
I had 64cc dart heads..by the time they chambers got reshaped they were almost 72!! Then milled to 62
Been milled a few times, finally at the point they cant be done again as it would cut into the valve job or making sealing the intake tough. Thats hot rodding!
As said tfhe modern shaped combustion chamber is where its at!! So many overlook that as a source of additional power.
i did a little playing last night. 4cc dish, .029 head gasket, .016 in the hole 11.06 with 58cc. 10.27 with 64cc. .8 diff in CR. above 10 to 1 the rule of thumb is 2% for each point of compression. so you are talking 7 hp on a 350 hp engine. now, this is with everything else identical. and any aftermarket head is worth a lot more than 7 hp over the best iron GM head. and you are not gonna feel 7 hp unless you are looking at your et and your launch will get more variation in time than 7 hp.
49cc AND a better valve angle...??? Probably a nice, tight, modern chamber too. Excellent. Too bad those dont sound cheap...
Bumping your compression, at that level is more like 3% per point, and 4% at the levels i'd be concerned about (basically... de-smogging a 8.5/9:1 engine). However, compression increase is more than just power. Its efficiency. I know that word is a capital offence on a Corvette forum, but some ov us care. Its also good for MPG (again, my fake apologies to the Corvettes should get 3mpg crowd...), and it just improves EVERYTHING. Hell, a higher squeeze even sounds better out ov the pipes.
A small, tight, modern design chamber is sooooo important, as the engine is basically designed around the combustion chamber. Using a (basically) almost SEVEN DECADE old design is just absolutely unforgivable... unless you are outright restoring the car to stock. Remember, those 'awesome' camel-bump LT1 heads are pretty much the same damn head as the 265 head... designed in what, 1953...??? Just with bigger holes. 1953. Man... thats when people were still flying across the country in PROP-engined planes... Half the country didn't even have a television at this point in time.
A nice bonus to swapping heads is maximizing the quench as much as possible.
