I found several threads that talk about the subject topic; however, none specifically address the removal of the dimmer switch under the dash. the rod activates the switch (loud click), but the headlights don't change from low to high beams,. I have removed the access panel under the column and ductwork, I located the switch and unplugged the connector, but its hard to tell exactly how the switch is fastened, due to accessibility. I can't tell if there are screws or if it is somehow clipped in place. PIcs would help immensely.. Any help would be greatly appreciated.
Follow these instructions to the letter.
The reason these steps are critical is if you just start removing screws you will also loose the correct placement of the ignition switch...
Your replacement dimmer should come with the stud and nut shown in step 2.
If your dimmer switch is not perfectly placed you also run the risk of breaking the pivot bracket your wiper/washer switch is attached to.
1977 Wiper/Washer switch is a 1 year only part....
