No start issue with new mini torque starter
Battery is good (new last fall and charged up on a battery charger). Wires cleaned up and greased with some dielectric.
Not sure where to go from here as this is the first car I've ever worked on. Have paged through the Haynes service manual and the Tom Wilson How to Rebuild Your Big Block books and searched for old threads here but still looking for some direction.
Short video below of how I have it wired up. Kind of hoping I'm just an idiot and have an obvious wiring error that is easily addressed.
My uncle learned this same lesson the hard way on his c3, As did I on another vehicle years ago. I also had an ignition switch get shifted and mispositioned on the column which caused this behavior.
Using a factory starter my engine turned over more slowly when it was hot after usage in traffic. I finally bought a MSD Digital Retard Box that allowed me to pull the engine's timing back while cranking. If the timing is too advanced this to will load up the starter and make it work harder. By pulling 20* of timing while cranking the starter spun the engine much easier and faster. When the engine "starts" the timing returned back to normal after reaching 400 rpm.
Today many aftermarket Ignition boxes offer this option and even my new Holley EFI system has provisions to do this. With the timing pulled back the engine cranks like a normal cold engine. After adding a Gear Driver Starter the engine cranks even faster with the timing pulled back. The combination of both is the best solution for a hot engine trying to crank.
Die-electric grease does not improve or help your electrical connections. Remove it and clean it from the contact surfaces and then make the connection again. Using it on top of the connection can slow down corrosion. I have seen people use it on the spark plug boots and it helps the boot from getting stuck to the wire's cap but if you put it on the part of the wire that connects to the spark plug it actually inhibits the spark from getting to the plug. I generally prefer to use battery grease and cover connections with it to keep the corrosion under control. Die-electric grease is not to be used inside connections. This can actually keep your engine from starting if too much was put into the Spark Plug caps.
IF you put Die-electric grease in between the surfaces of the battery and it's cables you are hurting the connection. Clean the connection and re-connect the battery without Die-Electric grease to have a good solid connection. To keep it free of corrosion then you can put either battery grease or Die-electric grease on top of the connection, JUST NOT BETWEEN the connecting surfaces. The only negative to using battery grease on a car is that dirt and dust can get stuck to the grease.
Here is a quote I found regarding Die-electric grease: "What is dielectric grease? Despite the fact it has "electric" right there in the name, it's a fairly common misconception that dielectric grease is capable of conducting electricity. In actual fact, dielectric grease is an insulator and doesn't conduct electricity."
Good Luck and I hope that this helps you a little with your Starter issues.
Best Regards,
Chris
I use a material known as DeOxIt to clean the surfaces free from corrosion. I use it on old light bulb contacts to clean them, afterwards the bulb gets more power and shines brighter. Any contact that is old and dirty would benefit from DeOxIt. It is a great contact cleaner and leaves a residual material that maintains the connection at its best.
I feel like an idiot but also glad that I don't have something more serious to hunt down... yet... The engine reved through the start and then died immediately. I started it a few times to get the gear paint marked. Pulled it out again to check the alignment and saw the marks go all the way down the valley of the gear tooth, so shimmed and reinstalled. Went to connect the battery and sparked started flying and ended up trashing the threads on the battery terminal bolts. I have the side mount terminals on this battery and they are simply the worst to connect because of the tight quarters of the battery box. Onto the next set of issues but at least I can rule some things out.
