Starter
Old Jun 6, 2022 | 10:31 PM
jgonzo's Avatar
jgonzo
Default Starter
Need some help. 82 wont start, battery fully charged, all dash lights come on. Key in ignition sets off buzzer when turned but no clicking sound from starter. How can I troubleshoot?
Old Jun 6, 2022 | 10:36 PM
augiedoggy's Avatar
augiedoggy
look for voltage at the connection for the starter solenoid when trying to start. if you have it then likely my guess is one of the battery terminal ends (or ground) has a poor connection to the copper wire. I had this problem myself. could be solenoid also or fuseable link which would also be ruled out by checking voltage at both starter 12v points.
Old Jun 7, 2022 | 06:52 AM
derekderek's Avatar
derekderek
big ground directly under battery box to frame is most likely culprit. it will pass enough for dash lights and voltage test but won't pass real amps.
Old Jun 7, 2022 | 09:25 AM
HeadsU.P.'s Avatar
HeadsU.P.
Here are your choices. Just pick one.
GRDS
Solenoid
IGN Switch
Neutral Safety Switch
Battery w/ low CCA showing 12.4V
Starter itself.
Fusible Link
Old Jun 8, 2022 | 01:02 PM
centralcalvette's Avatar
centralcalvette
I have a 69, which is simllar. Went to start it and it cranked for 2 seconds and quit. On inspection I found the starter wires corroded and over heated from excessive heat. It's going back together now. I also cleaned the ground from the battery at the frame and will remove and clean the engine ground. (On a 69, pass side attached to the oil pan.)
Old Jun 8, 2022 | 02:32 PM
Eric P's Avatar
Eric P
Hook your test light to ground such as starter mounting bolt , probe the big fat top terminal on the starter solenoid to verify test light works as that big battery wire should be hot at all times , then probe the S terminal on the starter solenoid marked S (it's the bigger of the two small terminal) , have helper turn key to crank position and S terminal should light up . if so replace starter , if not neutral safety switch or possible clutch switch or ignition switch not supplying crank voltage
Old Jun 9, 2022 | 08:31 AM
7t9l82's Avatar
7t9l82
Check the ground cable from the battery first. It's a common issue..
Old Jun 9, 2022 | 09:44 AM
7t9l82's Avatar
7t9l82
To Starter
