Front Frame Horn Boxing / Gusset
FYI.....car will have big block radiator....most likely Dewitts aluminum.
I read your post yesterday and went home last night to search my picture archives to see if I could post something to help you.
I did the same chevy power book mods to my 78 frame when I had the body off. I fully boxed the front horns on both sides. Unfortunately, I am in the middle of another project on the car and the radiator is out (it's a DeWitts aluminum like you) so I could not snap a picture for you with the hose and radiator. What I can say is that it fits, but it is super tight. I believe I had to remove the radiator hold downs up top and shimmy the radiator over to get enough clearance to grab the hose to remove it. My boxing has no indentations.
1.....Would it achieve the purpose of strengthening this area?
2.....Would it provide more clearance for the radiator hose?
Frankly, when I look at this reinforcement, I lack the understanding of what it is trying to do. The frame horns are further strengthened with the radiator support extensions, AND the front bumper extensions.....so the concept these are "twisting" under load is hard to believe. OR.....is it simply that the lower flange of the C section is deflecting under load, rather than the entire frame horn twisting. If this is the case a two inch bridge between the two flat sections of the C section, right at the bushing mount, should help. What is it?
I think the rationale behind boxing that area is that it will reduce the flex, both in general by increasing the amount of the frame that is boxed, and also due to the stress at that point from the stabilizer bar. Those mount points are under load when the stabilizer bar needs to twist so there is definitely a force there. Boxing just the mount portion would strengthen that area, but would leave an open C area between it and the rest of the frame (rearward side). In effect, the stronger part would move in unison, and twist in the open C.
The power book mods need to be looked at in context IMO. They were going racing and wanted every bit of stiffness they could get with what is there. Personally, I think the most improvement comes from the completion of the stitch welding and the gusseting of the lower A-Arm mounts (these things rip off on street vettes
).Will post some pics later so you can see what I have done.
In reality....I am not racing the car.....its all probably nonsense to even bother with it.....but I have a bare frame, a welder and so.....
I guess the only other thing to ask is ......does the radiator hose connect exactly in the same place on a small block radiator as it does a big block radiator????
.....My 2nd concern would be the parallelogram twisting of the upper & lower a-arm mounting structure "box". Solid engine mounts and the upper a-arm strut bar should help significantly here. I saw one guy who added a vertical side to side support inside the lower frame under the engine. Welded it in in real well. That was genius and he reported it really stiffened the front end. It should. But not sure it would be significantly stronger than just the upper strut bar, which is waaay easier.
.....My third concern would be torsional or twist or vertical flex in the s-bend sections. Very little can be done about this short of adding an upper engine compartment frame "cage" like they do on the race cars. Chevy added two vertical supports internally in this area to decrease the torsional twisting. It could use still more, but how would you add them internally?
.....Other frame mods would be far behind these in effectiveness. Aka the sway bar area.
.....Chevy tested a significantly thicker frame that seriously reduced twisting forces. However that idea was discarded because the car rode "worse". How little they understood handling in the early 60s. They were inadvertantly using frame flex as a "spring". Today's cars have somewhere from 2-4 times more torsional stiffness than these old cars. There is little you can do to change this without adding a full roll cage.
My advice: Just make the normal frame "powerbook" mods, especially fully welding the frame. That will help the most. And the strut bar. Then just enjoy it.
I guess am going to have to engineer an upper strut bar for my BBC with my mechanical fan. Most people say it won't fit. I don't agree. But I can be more persistant than most! LOL
As for the sway bar reinforcement, I think I am going to use the Ciro gussets as close to the sway bar mount point as I can.....little fitment problem there because the 68 they made these for has slightly different profile at the sway bar location.
As for the comment on reinforcing the crossmember, the fix I did is same as I did on my 77. I purchased a replacement lower crossmember plate from Zip. It is made to exact specification to replace the entire lower plate, from spring hole to spring hole. I cut it into THREE pieces, and added it as a doubler to the lower side of the crossmember. THAT fixes the ugly dented lower crossmember, and makes that piece 1/8 thicker, now with THREE layers of metal versus TWO. I would think it has some effect on strength, but mostly its a fix for the dented center portion of the crossmember. Win Win.
I have seen on this forum the guy who cut a slot across the lower crossmember, and added a 1/4 inch thick vertical plate from top to bottom of crossmember......great idea....I am just not doing it.
Lastly, I totally agree about the spreader bar.......we both are installing big blocks, and I would like to stick with mechanical clutch fan and factory shroud.....NOBODY is making that now. One forum member did it by adding a spacer between the clutch fan and water pump....providing the necessary clearance for the spreader bar. That may be the fix we are looking for, but I want to make sure it is not adding too much load to the water pump bearings. I don't think it takes much spacing.....but that is my plan to work on. I should have the frame on wheels with the VortecPro big block installed by end of year.....and then I can start working on the spreader bar.
With electric fans, like Dewitts dual Spall fans......a spreader bar is easy....and the only real reason I would consider electric fans.
The pictures above clearly show that whatever radiator this is....the lower hose fitting is INSIDE the frame horn C-section, and there would no way to box that horn completely. But that lower frame support looks alot like my 77......so this would be a small block radiator. That does not help. I appreciate the pictures though. Also, the radiator hose fitting on the big block is up higher on the radiator than this.....or the radiator is taller and extends lower.
In any case, what I need is to see pictures, just like above, of a factory big block radiator (or direct fit radiator like Cold Case or Dewitts) on a 69-72 Corvette......does anyone have these needed pictures?
