Boost L82 Engine
I want to share you the upgrade performance of my L82 engine 1979. All this parts fit without modification. Lots of fun after that
1) K&N air Filter
2) True Dual Exhaust : https://www.corvettecentral.com/c3-6...ht-tuck-322089
3) Patriot Headers : https://www.corvettecentral.com/c3-6...-shorty-323236
4) Mufflers : https://www.corvettedepot.ca/exhaust...inch-1978-1982
5) Trick Flow Specialties TFS-30210006 - 175 Cylinder Heads : https://www.summitracing.com/parts/TFS-30210006
6) COMP Cams 7644-16 - Pushrods : https://www.summitracing.com/parts/CCA-7644-16
7) COMP Cams 17005-16 - Rockerarms : 8) COMP Cams XE262H : https://www.compcams.com/xe262h
9) Edelbrock 2101 - Edelbrock Performer Intake Manifolds : https://www.summitracing.com/parts/edl-2101
I use the stock Quadrajet. Do I need to upgrade it ? What do you think ?
Thanks,
Personally I'm not a fan of vacuum secondary or vacuum air door carburators.
Sounds like a nice set up
The Quadrajet would be great. You might step up one size richer. Do that and adjust the carb before you do the tear down. Lars can do that for you if you are unsure of how to do it. It is nice to know your carb will be 100% right before you do the start up.
Recurve the distributor before you tear anything down so it will be ready to go later.
