Power window motor
Old Jun 27, 2022 | 01:41 PM
pawpaws toy's Avatar
pawpaws toy
Default Power window motor
Can the window motor on a 1980 be removed without clamping the regulator if the window is fully up?
Old Jun 28, 2022 | 05:56 AM
Edward Ackley's Avatar
Edward Ackley
dont quite under stand your post, but yes the window must be up to remove the motor
Old Jun 28, 2022 | 07:44 AM
Capt. Doug's Avatar
Capt. Doug
I don't know about your 80,but my 77 is not spring loaded. I think that is what you're asking.
Old Jun 28, 2022 | 07:54 AM
CraigH's Avatar
CraigH
I thought it says you should insert the bolt to lock the mechanism before removal !
Old Jun 28, 2022 | 08:04 AM
Capt. Doug's Avatar
Capt. Doug
Doing that will keep the window up and out of the way.
To Power window motor
