Ignition coil
Old Jun 28, 2022 | 03:27 PM
Batesgar's Avatar
Batesgar
Default Ignition coil
Looking to replace the coil on my 68 convert 327/350hp as part of a tune up because I have no idea how old it is. Old one is a Blue Streak and states use with external resistor and was installed with a condenser attached to the coil mount and connected to the coil positive terminal. The new one is a transistor coil I bought from Corvette Central with no statement about an external resistor.
Do I need to connect the old coil condenser to the new coil positive terminal or is it not necessary?
Old Jun 28, 2022 | 03:32 PM
Mr D.'s Avatar
Mr D.
The coil capacitor was for radio shielding. The statement "use with external resistor" should be a resistor wire installed in the ignition circuit from the factory.
Coil Capacitor
Old Jun 28, 2022 | 04:49 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
The new coil appears to be for a different application. Got any more details on what your setup is?
Old Jun 28, 2022 | 06:02 PM
wilcar's Avatar
wilcar
Your uc12x blue streak coil will probably outlast that "transistor " coil. Send it back and get another smp uc12x to keep as a spare!!
Old Jun 28, 2022 | 06:46 PM
Batesgar's Avatar
Batesgar
The coil is a Delco Remy 1115272 from Corvette Central. It’s listed as. Transistor Ignition coil for 68-71. Looking further at the box it warns it will be damaged if grounded by a radio capacitor. Further states it must not be installed in conjunction with a radio capacitor attached to either terminal.
So…..I will not hook up the capacitor and read better in the future. Good info for future reference.
Old Jun 28, 2022 | 07:02 PM
62corvette's Avatar
62corvette
Not sure why you bought a transistor coil. They should be used with TI amp and distributor, but the repros are notoriously unreliable. And overpriced.
Old Jun 28, 2022 | 07:17 PM
Batesgar's Avatar
Batesgar
Corvette Central listed multiple coils for the 68, this one seemed the best fit for the replacement of original equipment.
I’ll see how it performs with my stock ignition system and go from there.
Old Jun 28, 2022 | 09:47 PM
69427's Avatar
69427
Asking again for information. Do you have a Points or TI system?
Old Jun 28, 2022 | 09:58 PM
Batesgar's Avatar
Batesgar
Stock ignition point and condenser. I shouldn’t have ordered that coil but you can’t return electrical parts. I’ll put the Blue Streak back in till I order the non transistor coil from Corvette Central
Old Jun 28, 2022 | 10:35 PM
69427's Avatar
69427
You shouldn't have any trouble selling the TI coil at a later time, as it seems like they're in limited supply at times.
Just FYI; The TI coil needs higher current than a points coil to get the desired energy level in it, and a stock points setup will probably not allow the same higher current, but end up eating points in the process.
Old Jun 28, 2022 | 10:59 PM
Batesgar's Avatar
Batesgar
Corvette Central currently lists the coil as discontinued. Let me know if anyone wants it and I’ll sent it your way. It was a $140 coil but my mistake will be your gain.
Thanks everyone for the help.
Old Jun 28, 2022 | 11:51 PM
augiedoggy's Avatar
augiedoggy
honestly the original coil will be better quality than the mexican or chinese replacements sold today which have a very high failure rate.
Old Jun 29, 2022 | 07:26 AM
stingr69's Avatar
stingr69
If the old coil is still working I would not replace it. The ones available today are of questionable quality. If it works, don't fix it.
Old Jun 29, 2022 | 07:39 AM
Batesgar's Avatar
Batesgar
Thanks for the advise. I assumed this Blue Streak coil wasn’t original and in need of replacement. I’ll take your advice and just go with it till it gives me problems.
Old Jun 29, 2022 | 09:36 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
The Blue Streak isn't original...but generally they were good stuff.
JIM
Old Jun 29, 2022 | 09:55 AM
Batesgar's Avatar
Batesgar
That why I went Delco as I assumed that was the original manufacturer….just bought the wrong one. But I’m now concerned even the right Delco coil might be foreign crap.
Old Jun 29, 2022 | 02:58 PM
Batesgar's Avatar
Batesgar
Just finished the swap. Amazed how much idle rpm, point dwell and timing adjustments were required between the 2 coils.
Old Jun 29, 2022 | 09:33 PM
62corvette's Avatar
62corvette
Hi,
Sent you a pm on the coil.
Old Jun 29, 2022 | 09:56 PM
Batesgar's Avatar
Batesgar
Replied to you pm
To Ignition coil
