'82 Corvette Rear End Asm. Take a Look
Re: '82 Corvette Rear End Asm. Take a Look (1yy07)
No, you have an FE7 equipped 82, which as it seems ALL had the alu struts. There aren't that many FE7 equipped 82's. Most have the standard suspension with the monoleaf.
Marck
Marck
It looks like I too have the FE7 option. H beam struts, heavy duty steel spring and rear sway bar. Production # 25232.
:cool: :cheers:
:cool: :cheers:
Re: '82 Corvette Rear End Asm. Take a Look (PROSOUTH)
It seems that there was a scorched place about the size of a dime from a machine that made the door panels right at the top rear corner of them.
Please tell me more about this
Marck
Location: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Re: '82 Corvette Rear End Asm. Take a Look (Twin_Turbo)
Marck, I was a young man about your age in 1980. My Ex-Wife got the '78 White Coupe and I had just purchased a '70 454 4spd A/C Bridgehampton Blue Coupe with black.....................
Oh, you mean the '82 CE :D
That's about the whole story, somehow the vendor that supplied the door panels let their Quality Control slip by some faulty product.
At the top rear of the panel, approximately where the locator screw goes, is a scorched spot about the size of a Dime. The flaw was identified and a hold was put on the CE's until replacement Door Panels could be installed.
I earlier posted that Chuck the Rep had bought 100 sets of them, it was actually 50 pair. I purchased 10 pair to trade on at the time. I was going to put a set in my '70 with the Silver-beige Carpet from ACC thay will custom build carpets if you want from their factory. I was a dealer of theirs at the time.
The Scorch was on both sides. I have no idea how the machind worked or why it was that hot. It was a pronounced little spot.
One more thing of interest on the Collector Car was a Silicon Injection of the leather to help preserve the color and resist wear. This also made it impossible to dye later.
I sold '82 DUKMAN Chris Eisemant a Trooper from PA a set for his car. only one of these was worth using as a man I sold them to tried to dye the panels and ruined the drivers side panel. I sent them to Chris and I think he bought an after market panel to replace the bad one.
It is possible that some of these were in the field and that a Field Complaint was the reason for discovery. Another idea is that the first cars made had already been shipped to foreign countries to enable a target release date. Merely speculation on all of this.
You noted that a friend of your has a '82 CE. Does it or yours have the standard US tail light lens in it or are they Yellow? Yellow/Red or what? JIM
The CE has standard US lights, with the front changed to E marked lights (the hellas with H4 removeable bulbs)
C3's were not oficialy imported and sold here in Europe. I think this CE came from the US somewhere in the beginning of the 90's because it has early 90's plates on it
Pretty cool info, a lot of people don't know this stuff :)
Marck
Marck
